Like Tree495Likes
JConcepts Thread
Old 02-08-2023 | 06:25 AM
  #10411
PW's Avatar
PW
Originally Posted by Cain
So this is going to be an odd question, but figured give it a shot.
A track here for modified classes has what we call a "legacy" tire rule, basically you have to run non-carpet style tires on the carpet for modified. things like clay tires, etc, treads are fine but have to be soft tires. Right now looking at some things that appear to work, stuff that is softer than clay appears to grip better even if sauced with sxt 3.0 (was all over the place with another brand clay tire).
Anyway, I am a bit intrigued by the Rehab 1/10 buggy tire versus the Sprinter since it has a very dense pin pattern, so could last longer wear wise versus something like a jconcepts flipout (used these in the past years ago, felt like a pinned carpet tire but of course soft and fast wear).
My question is this, when looking at the available compounds, Blue versus Green, haven't not used Blue in a LONG LONG time, how does it compare softness wise compared to Orange clay compound?
Wow....Seems to be a bit of a mess not just running carpet tires
To answer the question, blue compound is the same rubber as green, just slightly firmer. Orange was our original hot weather hard compound for sugared or grooved outdoor tracks and doesn't relate to clay at all.
Gold (soft) and Silver (super soft) are our clay compounds.
PW is offline
Old 02-08-2023 | 06:41 AM
  #10412
Cain's Avatar
Tech Legend
Yeah they have concerns on carpet wear so for modified classes they only allow non-carpet tires. I hope one day they change that as I think that could help the classes but will see. Could also be similar I guess to some tracks in Europe on carpet running the Schumacher Honeycomb as a spec tire versus cactus, etc. Tried those here but definitely too stiff, pattern though looked interesting.
Cain is offline
Old 02-09-2023 | 05:42 AM
  #10413
Cain's Avatar
Tech Legend
Nice to see a 1/8 Turf option! Recall these being tested out, was any testing done with the Nessi's also in the front but with some pin trimming / sidewall gluing?
Cain is offline
Old 02-09-2023 | 05:52 AM
  #10414
PW's Avatar
PW
Yes, that is an option as well .
Cain likes this.
PW is offline
Old 02-09-2023 | 06:18 AM
  #10415
Cain's Avatar
Tech Legend
From what you all saw what was a setting you liked when doing that? (ex- 2 pin rows outer trimmed, 1 inner, sidewall glued, etc). Excited to see these in action since one of the tracks you all tested at seems to have a pretty good turnout for 1/8 E buggy turf racing
Cain is offline
Old 02-09-2023 | 06:30 AM
  #10416
PW's Avatar
PW
Unfortunately I wasn't involved in the testing, so not sure the details. It will just be an option depending on particular conditions and personal preference.
Cain likes this.
PW is offline
Old 02-09-2023 | 07:53 AM
  #10417
Originally Posted by Ostach24
Are there any ti turnbuckle kits from jconcepts that will fir the xray cars? Looking for both buggies and the truck. Thanks in advance.
Sorry, no turnbuckles for the Xray cars.
Theoretically, the TLR 22 5.0 turnbuckles could work for Xb2 & XB4. Stock the TLR turnbuckles measure 50mm vs the Xray 55mm and the Lunsford set used 52 & 57mm for Xray - the 57mm on the rear caused some binding if using a short rollcenter locations
gotheframe is offline
Old 02-09-2023 | 10:50 AM
  #10418
Cain's Avatar
Tech Legend
How much of a difference in offset are the JCO3381 wheels versus the JCO3353 wheels and which of these wheels are considering the go to ones to use with the Tekno EB410.2 and Yokomo YZ4SF2?
Cain is offline
Old 02-10-2023 | 05:30 AM
  #10419
PW's Avatar
PW
I believe the 3353 wheel is 1.5mm wider per wheel, but I'm not sure of the specs for the Tekno or Yokomo.
PW is offline
Old 02-10-2023 | 07:19 AM
  #10420
Cain's Avatar
Tech Legend
thanks for the info. I'll have to sit down and measure the width sometime for comparison. with Yokomo looking like they at times are using Jcon stuff on their cars, be curious if the wheels they make are just jcon wheels with a yokomo badging.
Cain is offline
Old 02-10-2023 | 10:35 AM
  #10421
PW- Green reflex for 1/8 buggy has been out of stock for some time now along with a lot of other popular tires. Any idea when we can expect better tire availability?
Eric Tomczyk is offline
Old 02-10-2023 | 11:13 AM
  #10422
PW's Avatar
PW
Distributors and dealers are getting priority at the moment and Reflexes as well as other treads are shipping out daily. So we have them in the building and they are shipping, unfortunately they are not putting them on the website for direct sales. I would suggest calling to place an order and you will probably get some
PW is offline
Old 02-10-2023 | 11:19 PM
  #10423
TOO-TALL's Avatar
PW,
I see the S15 body for the B4 nitro car has released.
What are the differences from the 3.2 S15 body?
TOO-TALL is offline
Old 02-13-2023 | 05:26 AM
  #10424
PW's Avatar
PW
Originally Posted by TOO-TALL
PW,
Well the obvious changes are the cutlines to fit the B4 and dimple for the antenna. We also filled in the deep pocket behind the cab for extra clearance for the carb and we also extended the cab back for a future change coming .
PW is offline
Old 02-13-2023 | 10:19 AM
  #10425
PW's Avatar
PW
Please Click Here for our latest 2023 Tire Reference Guide
Cain, MiCk B, stanleyw808 and 1 others like this.
PW is offline
