JConcepts Thread
When will the pre-mount Pin-swag 2wd front's be available in the UK? Part No. 3181-201011.
https://jconcepts.net/pin-swag-2wd-front-pre-mounted
I really want to try these as an alternative for the usual Schumacher LP cut stagger but they don't seem to be available anywhere?
Thanks.
Thanks.
Thanks.
Thanks.
Cool to see a step-pin style tire back out there, do you think you all would make a dirt style compound version of these like Green or blue?
For the new pin swag 4wd fronts, are you finding you still need to glue the sidewalls like we do with the fuzzbite 4wd fronts? For rear tires do you all like to still combine them with fuzzbite rears or pin swag rears?
They still glue the sidewalls, but more inline with the 2wd. Still using Fuzz Bite rears 100% of the time on black carpet.
Production samples have been given the green light, so it's has to be very close.
Unfortunately it's not the tires holding us up, it's the inserts. So inserts are in transit and once they arrive, they will begin shipping again very shortly
Hate to post another "when will this item be available" question but........ I've had 1/10 rear buggy double dee's & sprinters on back order since December. Can you give me some hope?
Is it possible to buy your carpet foam inserts for different tire types separate? For example, the stadium truck carpet foams?
As part of that, how do the stadium truck carpet foams compare to your foams you include with your dirt style tires like the stadium truck goosebump? Looking at foams here since the track is bumpy for your molded inserts that are pretty stiff for these conditions, but don't see the foams to be bought anywhere and comparing how the carpet and "dirt" style foams feel by hand.
It's been a long time since I've handled/used the white foam that comes with the Goosebumps, but I would probably say it's just slightly firmer/more dense than the grey carpet foam.
494Likes
