Like Tree387Likes
JConcepts Thread
Old 04-06-2018, 07:19 AM
  #9661
PW
PW's Avatar
Originally Posted by Cain
what tire do you have that is the most similar in performance to a proline clay positron, or, better
Gold Dirt Web's is our signature indoor clay tire - has good forward traction and really good side bite.
Gold Space Bar is our newest indoor clay tire - has really good forward traction and med side bite. This tire is really good on high bite tracks were you need more rotation/cornerspeed.
I really like using the FDJ Dew (green dot) tire sauce for med/low bite conditions.
PW is offline
Old 04-06-2018, 07:31 AM
  #9662
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
thanks. got a track here that is grey ozite carpet with a non-hardpin tire rule, so its been common to run things like slicks and clay compound tires. The hot tire right now appears to be the positron or similar treaded clay tire. after initial hick up the octagons have been performing well, but would like a bit better bite that a treaded tire would give so was curious. I'll keep those tires in mind.
For your astroturf tires, what front tires do you recommend for 4wd buggy that in general don't require trimming? Will be running 2wd &4wd buggy, and 2wd stadium truck.
Cain is offline
Old 04-06-2018, 07:39 AM
  #9663
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
I have never trimmed the swagger fronts on Astro.
Matt Trimmings is offline
Old 04-06-2018, 07:45 AM
  #9664
PW
PW's Avatar
The Swaggers for 4wd would be the choice. If you still have to much front traction, you can glue the sidewalls of the tire.
Cain likes this.
PW is offline
Old 04-06-2018, 08:01 AM
  #9665
mes
As this is the JConcepts thread, I'd say you are looking for Swaggers #3166. I never understood why the EOS switched to the Cactus front tire when the 4WD stagger was a top performer. 4WD front rib tires FTW!
Cain likes this.
mes is offline
Old 04-09-2018, 08:55 AM
  #9666
Tech Legend
Cain's Avatar
thanks. grabbing up tires here. Think I'll standardize on Jconcepts for turf for tires
Right now it looks like the main carpet compound is "pink" from jconcepts, at least what I see in amain, how does that compound compare to a schumacher yellow or blue?
You guys looking to offer premounts at all?
Any thoughts on a lockness style stadium truck rear?
Cain is offline
Old 04-09-2018, 10:17 AM
  #9667
PW
PW's Avatar
Pink compound is closest to yellow. We are looking into premounts, but nothing soon, and no other truck tires at this time.
PW is offline
Old 04-09-2018, 10:25 PM
  #9668
STLNLST's Avatar
Trader Rating: 32 (100%+)
All packed up for the April Fools race. Dirt Webs and Space Bars and Octagons ready for whatever the track throws at us. I'll try to be the taller PW at this event. Good luck to everyone racing JC this weekend wherever you race.
STLNLST is offline
Old 04-10-2018, 07:10 AM
  #9669
mes
thanks. grabbing up tires here. Think I'll standardize on Jconcepts for turf for tires <img src="classic_images/smilies/smile.gif" border="0" alt="" title="Smilie" smilieid="1" class="inlineimg" /><br />
<br />
Right now it looks like the main carpet compound is &quot;pink&quot; from jconcepts, at least what I see in amain, how does that compound compare to a schumacher yellow or blue?<br />
<br />
You guys looking to offer premounts at all?<br />
<br />
<br />
<br />
JConcepts pink is a little harder than Schumacher yellow, but way softer than Schumacher blue. It combines a little less grip and wear vs. the Schumacher tires, and one some astro tracks and most carpet tracks, our fast guys prefer the truck Pindowns over the Schumacher Minipin to prevent traction rolling. In any case, front Swaggers seem to be the go-to stadium truck front tire. Larger pin rear tires (e.g. Schumacher Minispike) seem only to be an option for people looking for longlife instead of racing tires.
Cain likes this.
mes is offline
Old 04-10-2018, 05:30 PM
  #9670
Team Pink's Avatar
Trader Rating: 20 (100%+)
Except PW probably does not use a Tinker Bell suitcase to travel to races. HAHA!!! Good luck this week buddy.
Team Pink is offline
Old 04-11-2018, 05:25 AM
  #9671
Trader Rating: 36 (100%+)
PW, any ETA on the stadium Carvers yet? Thanks
nitrousdave is offline
Old 04-11-2018, 05:52 AM
  #9672
PW
PW's Avatar
They let me know yesterday that it would be end of the month or first week of May.
PW is offline
Old 04-11-2018, 07:30 AM
  #9673
Thank you, that's cutting it pretty close with my first race on May 19. May have to go with brandx to make sure I have tires and leave the carvers on order.
Old 04-18-2018, 11:46 AM
  #9674
Tech Legend
Cain's Avatar
when running the pindows 4wd fronts do you guys cut any pins? If so, how many rows?
Cain is offline
Old 04-18-2018, 11:52 AM
  #9675
PW
PW's Avatar
Honestly we don't ever use them, we always use the Swaggers . My guess is if you are using the Pin Downs in the front, then you will need to cut some rows out.
PW is offline
