JConcepts Thread
#9391
Do you have any pics or vids of the track?
Ray
#9392
#9393
Can anyone tell me if the jconcepts strike 2 body for Associated B3 electric will fit the Mugen MBX7R eco?
#9394
It depends on the soil type and how hard / abrasive the base is. The harder the base, the more likely I will use a 3D. On buggy I usually use a Bar Code or Dirt Web front to match the 3D rear. Its been a while since I ran truck, but usually I would run a DD front when running a DD rear. I may run a DD front with a 3D rear if Im looking for smoother steering on a looser surface, but I probably wouldn't run a 3D front/ DD rear.
Ray
Ray
#9396
Hi mate,
I put together a JC tyre chart a few years ago which shows some of the tyre options I use on our tracks. Its hard to say for sure without a picture of the surface, but the general rules I follow are:
- If the track is soft, then Flip Outs are my go to. They dig into the surface better than anything else. Based on your description, these may be the go.
- If it has a hard base but dusty on top, then 3D is an option. These are a combination pin / bar tyre. But they wont dig into a soft surface the way a Flip Out will.
- Double Dees are good if the track has a damp line but loose on top.
Hope this helps
Ray
Hope this helps
Ray
#9397
Tech Legend
Trader Rating: 51 (100%+)
#9398
Is there a new clay compound or treaded tire to replace the dirt webs coming out? I've noticed dirt webs on sale everywhere. Also, what is the best tire/compound for outdoor blue groove with dusty edges (prloline x2 electrons seem to be what everyone is using but want to try JC)?
#9399
We have been using Dirt Mazes (R2/O2 compound).
#9400
Help wih tire selection
The track I run at used to run astro, has moved, and is now running on black crc. I run stock buggy, stock truck, and mod 4 buggy. Just put new tires on the stock truck and they are hooked up out of the package.
The jcon pin downs and swaggers in pink have been exceptional on the astro, and they seem to work very well on the black crc. They have plenty of run time built in. Love them! With a little pin trimming and ca, it's what the fast guys run so, I do too.
Here is my question now. We will be going on a south west road trip in a few weeks and may run some outdoor on unknown surfaces and possibly indoor clay.
Probably just pack the stock buggy.
So what tire would I want to have on hand to be able to run? Clay? Dirt? Not sure where it might work out timing wise, but want them on hand.
Thank you, Roger
Thank you, Roger
#9401
Thank you, Roger
Thank you, Roger
#9402
Seeing that they have an indoor and outdoor track and not sure what day Wed or Sat we might get by, info on both would be greatly appreciated. I don't get to race outside so that would be real cool.
I'm in MN and want to get into more outside racing, but time is pinched in that regard, so I get my fix indoors.
thank you, Roger
#9403
I really want to make a stop at MHOR R/C Raceway in Aurora, CO. Have them marked on Google maps and it could work out timing wise on the way out or back. Both would be even better.
thank you, Roger
thank you, Roger
Outdoor looks to be kinda loose, so I recommend green Double Dee's or Flip Outs in the rear and green Rips in the front; all with the stock white inserts.
#9405
