JConcepts Thread
#9361
#9362
just curious what some of jconcepts top drivers use for traction compound. what does ryan cavalieri, or spencer rivkin use. what would jconcepts recommend for dirt webs or space bars on clay.
#9364
#9365
If you run 3Ds on a 1/10 4wd buggy on the rear, what do you run as the front tire?
#9366
Tech Legend
great thanks. Do you guys ever do a stagger of the compounds used? By that I mean where if you run say blacks in the rear do you go with greens up front at times in 1/10 4wd or do you run same compound always front and rear? Mind, you this is old school dirt conditions
#9367
Almost never, but it has happened on some occasions. If anything, it sometimes happens on extremely high-bite when trying to make the car easier to drive. I would recommend trying it for your conditions and do what's best for you and your track .
#9369
#9371
Any plans for an Illuzion shell to fit the 22 4.0?
#9372
#9373
Any news on the B6 aluminum front ball stud mount? Thought this was originally due out in April?
#9374
