Like Tree387Likes
JConcepts Thread
Old 06-14-2015, 08:24 PM
  #8431
jk racing's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Brandon Powell
need a small pin sc 4x4 tire between double dees and pressure points. Recommendations? Loamy, wet outdoor
3Ds?
jk racing is offline
Old 06-15-2015, 01:44 PM
  #8432
PW
PW's Avatar
Originally Posted by mes
Is it too early to say if the Team Associated SC5M will run the +3 Hazard wheels #3344 or the #3352s?
It has already been discussed, it is going to use zero offset wheels.
I spoke with Team Associated and the truck is the same width as the SC10, which means you will still need the +3 Hazards to make it max width (ROAR).
I would recommend the Lil Chasers - Click Here
PW is offline
Old 06-15-2015, 05:00 PM
  #8433
Originally Posted by Micah123
They came with dirt techs. Previous set came with blue foams that worked fine but new dirt techs are way firm for stadium truck tires. Run at sdrc in san diego which has very good traction. thanks for the input. was planning on 1 hole per rib but will compare 1,2,and 3 before re gluing. thanks again.
Went with 3 holes per rib and still plenty firm. Wondering if I should cut down ribs to soften more. Feel free to chime in if you have already been thru this process. Will not glue until tomorrow.
Micah123 is offline
Old 06-15-2015, 05:36 PM
  #8434
aeRayls's Avatar
DO NOT cut the truck foams!!! They will be way too small! I've already done it. Just mount em with the holes and run em. They will break in!
aeRayls is offline
Old 06-15-2015, 07:58 PM
  #8435
thank you sir. seems like 3 holes per rib is just about right. appreciate the input.
Micah123 is offline
Old 06-29-2015, 09:12 AM
  #8436
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
Default B5M Bodies
What are the different handling characteristics for the finisher and silencer?
Running a FL w/17.5 (if that matters)
KAWIDAD is offline
Old 06-29-2015, 09:16 AM
  #8437
PW
PW's Avatar
I personally think it's more mental then anything, but the Silencer is thought to be a little smoother and more locked in. The Finnisher is a little freer, more rotation.
PW is offline
Old 06-29-2015, 09:22 AM
  #8438
Arrow
PW - I haven't seen this question asked yet on the soon to be released SC5m, but do we know if the current line of JC SC bodies are a direct fit with the current body mount holes or have they been moved to accommodate the mid motor setup. Thanks in advance.
flintTRDTC is offline
Old 06-29-2015, 09:29 AM
  #8439
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
any plans on 2.2 smoothies?
Wildcat1971 is offline
Old 06-29-2015, 09:46 AM
  #8440
PW
PW's Avatar
Good question; I don't know and will have to find out. We unfortunately don't have a kit yet to check body mount placement.
It's in discussion, but nothing yet.
PW is offline
Old 06-29-2015, 01:18 PM
  #8441
PW
PW's Avatar
Spoke with AE and they said the front mounts are the same, but unfortunately the rear mounts are further back compared to the SC10.2
PW is offline
Old 06-29-2015, 01:23 PM
  #8442
hollywood3705's Avatar
Any thoughts on the current trend of 60mm tires and wheels? By that I mean do you perceive it as a tuning options or the next way all tires will be. No one can seem to agree so far but I've also noticed no new tires in 2.2. Any insight as the the direction paul?
hollywood3705 is offline
Old 06-29-2015, 01:36 PM
  #8443
PW
PW's Avatar
I personally think it will continue to be a tuning option unfortunately. Truthfully it's not an option that was really needed, but now its here along with the added cost and confusion .
PW is offline
Old 06-29-2015, 03:03 PM
  #8444
Thanks Paul.
Old 06-29-2015, 07:59 PM
  #8445
I sadly agree...just wish jcon would offer some of the newer tire patterns in 2.2
I know it's crazy cost but just a thought.
Thanks paul
