JConcepts Thread
#7771
Inserts
Hello guys.
So our indoor season is starting up. We race on a hard packed track. Usually dusty/low bite.
I got some new Dirt Webs in Gold and J Concept medium inserts.
The guys at the track were saying that its too firm of a tire to get any traction. I went to practice and the rear was on ice.
Once tires are glued , is there any way to disassemble them to remove the insert and modify it and then replace it? Or once glued, its done?
What do you guys do to modify the insert for indoor tracks with low bite?
Also, when do open cell inserts work in rear buggy (22 2.0) tires? I always choose closed cell foam. Don't know what the diff. between the two are handling/weather wise.
Tom
Tom
#7772
Just wondering if someone can help with compounds. Our track runs gold dirt webs or barcodes on 2wd buggy and was wondering if it would be the same to run silvers? I know they break in faster but is the compound very close to gold or will it be a noticeable difference?
#7773
Hello guys.
Tom
Tom
Basicly, take a brand spankin new Xacto blade and cut just above the glued bead on the inner sidewall. Remove old foam, insert new foam and re-glue. run a small bead on the outside as well just for security.
Or you can soak one side in acetone and hope you can re-glue them after. Hasn't worked for me yet though.
For tires, try the Splitters or Hybrids. They both work very well on loose dusty tracks around here.
I would findout for yourself about the open and closed cell foams. I haven't liked closed cells for most of the tracks I run.
#7775
I hope JC come out with 1/10 2wd front double dee's. I like the PL front hole shots but I always liked the double dee's better.
#7778
#7779
Will any of those new 1/8 scale tires come out in 1/10 scale?
#7780
#7782
Super Moderator
Trader Rating: 31 (100%+)
#7783
Super Moderator
Hara did a really cool video a while back. Don't know if its on YouTube or not. And it was for 1/8 scale, so if you are doing it for 1/10 scale which really doesn't take the force, Im going to assume it will work.
