JConcepts Thread
#5371
#5373
if you are spot on with your gear mesh, and are positive that the motor isn't moving, then you have a bend in something.
Check the motor plate, top shaft, and pop the motor out and put a pinion on it and give it some throttle (not a lot). Watch the pinion just to make sure there is no wobble. There shouldn't be, because if there was you would hear it and your motor performance would be poor. But check it anyway just to be thorough.
#5374
Well I took photos but mess up the transfer and most were deleted. So here is one. Upon further review only the outer edge got worn oddly...the side toward the motor mount looks like new. Also the teeth aren't worn down they are worn in from this edge shown.
The motor shaft spins true...no bend...the top shaft spins true, no bend...the motor mount looks straight to my eye but maybe it's tweaked?
#5376
Super Moderator
Trader Rating: 31 (100%+)
Something is wrong, you can see slipper pad on one side and not on the other.
on a side note, ditch the cheap steel RRP pinions. Pay the extra money for RRP absolutes or another brand as long as they are hardened steel.
I've run the black anodized aluminum ones from RRP as well without issues. Indoor with minimal dust of course.
#5378
How do you assemble a slipper wrong? Seriously there is a plate on the inside, the slipper pad, the spur gear, another pad, the other plate. The top shaft aligns it all.
It functioned properly, actually I was more happy with the performance than I was with the Losi spur and pads. But the odd wear pattern concerned me.
#5381
My Mono wheels for my TLR 22 have a bluish-gray tint to them. Anyone else have this problem?
I dyed the first set blue but on my next body I'm wanting to go with white as the main color but with the wheels wing so off-white it won't look good. Not sure if I just got a bad set or if they all have a off-white look to them...
#5383
How soon on Bro-Codes?
#5385
