Like Tree495Likes
JConcepts Thread
Old 05-21-2012 | 08:53 AM
  #5116
double dee tire supersoft are available? what are part number double dee tires ?
taztal3 is offline
Old 05-21-2012 | 09:45 AM
  #5117
PW's Avatar
PW
Originally Posted by icucmerc
Where can I find info on how to choose the right inserts for my tracks, and or drive skill for a losi 8ight 2.0 B, I like running subcultures, and AKA's Impacts
Not sure; but we normally recommend softer inserts on bumpy and or slippery surfaces and med inserts on smoother, higher bite surfaces.
When is a good time to use orange compound! Are track is being run dry now alittle dusty blues work but pretty much are done in two runs looking for good traction with better tire wear if possible thanks!
Orange compound is designed for high temp/high bite tracks with little or now dust. Tire wear will be high regardless of compound in those conditions, but orange might get you one more run if temps and traction are at it's highest.
What class; 1/8th buggy, 1/10th buggy, SCT?
PW is offline
Old 05-21-2012 | 08:13 PM
  #5118
1/8 buggy
taztal3 is offline
Old 05-22-2012 | 05:30 AM
  #5119
PW's Avatar
PW
Originally Posted by taztal3
1/8 buggy
The part # is 3007v2-02 and we are currently out of stock, but if you google the #, you will find several shops with them in stock.
PW is offline
Old 05-24-2012 | 09:43 AM
  #5120
double dee truggy tires will fit on elevated 1/8th truck wheel standard ?
taztal3 is offline
Old 05-24-2012 | 09:59 AM
  #5121
umm winning's Avatar
Are DD's in the making for front 2wd buggy? And is there a Rear tire that is similar to the PL holeshots, besides the DD's?
umm winning is offline
  #5122
PW's Avatar
PW
No; they are designed for the older, standard bead wheels.
PW is offline
Old 05-24-2012 | 10:25 AM
  #5123
PW's Avatar
PW
Yes....No ETA though.
We now offer the new Hybrid, but certainly it's own tire.
PW is offline
Old 05-25-2012 | 05:39 AM
  #5124
xrayrc's Avatar
Hey PW 3ds for sc any eta? They are working great on the 1/8 buggy
xrayrc is offline
Old 05-25-2012 | 05:57 AM
  #5125
PW's Avatar
PW
They are in production now, but not sure of the ETA.
PW is offline
Old 05-25-2012 | 12:30 PM
  #5126
Dane's Avatar
I'm running 1/10 buggy about to mount some JC tires. Should I round the edges of the open cell inserts?
Dane is offline
Old 05-25-2012 | 02:23 PM
  #5127
PW's Avatar
PW
I don't ever round the edges on the stock foam in the rear.
PW is offline
Old 05-25-2012 | 02:32 PM
  #5128
Dane's Avatar
Thanks for the info. How is it used on the front? Rounded less agressive?
Dane is offline
Old 05-25-2012 | 02:36 PM
  #5129
PW's Avatar
PW
We normally run a rear insert narrowed about 3/8" to 1/4" with rounded edges in the front. If you use the stock front insert, don't round the edges.
PW is offline
Old 05-25-2012 | 02:50 PM
  #5130
Dane's Avatar
Thanks Paul for the advice. This is why I spend my hard earned money on JC products.
Dane is offline
