JConcepts Thread
#4846
I know this has probably been asked before and I did a search but didnt get a clear answer.
Ive tried some other clay compounds in the past and didnt have much luck when the track dried out. So far in almost all situations the pinks have been working, but Im just looking for a tire that would work just as well with some more life in them...tires can get costly after a while
#4847
Good luck.
#4849
They need a slight scuff in the front to get rid of the push, after that they steer more then tapers. Proline closed cell in the rear, run them a few times and scuff em in. Motor spray after u clean em and then i liked devils spit on em I found bk bars are starting to suck for me. Greens last night were great all around.
#4850
Thats what I am afraid of...I was hoping someone from Jconcepts could chime in and shed some light on the issue. I have dozens of like new Jconcepts tires and adjusting to track conditions without knowing compounds is very frustrating.
Would have made things so much easier for the end user if they had a separate mold or more permanent marking for each compound.
#4853
Same here. Always mark the direction, compound and insert. The best way I can think of to figure out the compound is by feel of how soft the rubber is when the dot is gone.
#4855
Does anyone know when the 3ds are expected to be realesed.
#4856
#4857
#4858
#4860
I think they were shown on the video Jason did at the Nitro Dirt Challenge. The battery brace has just a little different shape to it than stock, looks like its going to be easier to move the battery around without trying to figure out where the wires are going. The body mount brace will simply go over the current piece - its should be very effective, I have made a set of graphite body mounts for my TQ SC and they lasted over a year of hard abuse - it really helped keep the body from flexing in crashes.
