XXX-4 Question
#46
Originally Posted by ßᣣ‡§†‡ç
they arent that fragile. but wat u wanna stock up on is front shock towers and front arms and spindles
#48
Originally Posted by Drift_Buggy
Yes but he said as a set not each like amain
Cheers
Cheers
AssosRacer-most guys that run the aluminum blocks and front pivots stay with the graphite inner pivot pin holders.They are a little cheeper and faster to replace stock caster blocks and it keeps a fairly cheep "weak" point.
You are right in that beefing up one area only increases the stress on other parts.
#50
I e-mailed them and they said they are each and other people on the internet have said they are sold each. Does anyone else know? If they are a pair then I am buying some tonight
Cheers
Cheers
They are sold as a PAIR for$39.99.
I raced there tuesday night and seen them on the wall,(2)per package(left and right). Yes they are in stock.I just called their hobby shop to verify.
#51
Originally Posted by AssocRacer
I've never broken one of these. I don't understand why everyone else seems to break them. I'll bet i've got 20 of them sitting in my parts box. I've broken spindles, diff cases, shock towers, and one arm, that's about it. Dunno how you guys are breaking these parts.
I heard that some guys have replaced them with the BJ4 Alum carriers. At $22 for the set (L & R), it would be better deal for those who need them.
#52
the bj4 ones are different in heigth than the amain ones and also the amain ones have an extra camber change adjustment . and kevin the lexan front bumper helps minimize the front end bottoming out on the faces of the jumps and also on the 2x4 chunk landings that the xxx4 mimicks as it is 1/4 inch less protrusion out of the front of the chassis.
later y'all
Monty
later y'all
Monty
#55
Originally Posted by Alltapdout
Whats this thread doing on page 10?
Lets bring it back!
Lets bring it back!
MM5700, nickel-plated RRP 15T pinion, stock 92T blue spur
#56
later y'all
Monty
later y'all
Monty
i have the a-main castor blocks as well as some bj4 ones i modified the crap out of. i've been running the bj4 parts since i can run a real hinge pin with those.
#57
OK, here's a question. Mine used to be nice and quiet, but now makes quite a bit of gear noise. The pinion and spur look fine. How do I get it to pipe down?
Loosen the motor mount and turn it while its running to see if is quiets down
#58
Sounds to me that the gears are not spaced correctly..too tight.
I actually wanted to post that Q in the other thread since this one seems to be more about parts breakage, but I got the 2 confused.
Here's my contribution for breaking stuff:
I broke the chassis in a head-on collision with a stadium truck. Snapped the front shock tower mount clean off the plastic chassis. With no plastic ones available, and a new graphite one being about $50-60, I fixed it with epoxy, fiberglass tape, and some 1/8 AL plate. So far, so good.
#59
I know you mentioned the pinion and spur look fine, but I'm going to guess the pinion is worn out. Is it a Robinson? They wear out surprisingly quickly.
Put a new Losi pinion on. Cheap to try. Losi pinions last a good long time.
#60
Yes, it's a Robinson. Not one of the cheap ones from the six-pack either. What does worn out look like?
