Schumacher cougar LD3 >
Like Tree317Likes
Old 02-08-2026 | 06:49 AM
  #646
Originally Posted by Pistol123
Looks like we have an official 5 gear conversion kit from Schumacher now. Interesting for the carpet drivers out there.
Theres a lot of upgrades out for the LD3 - hopefully they will realise an LD4 soon that includes some of these!
BuggyFan21 is offline
Old 02-08-2026 | 08:40 AM
  #647
There will not come a LD4. These are the news from EOS in Daun.
Muecke is offline
Old 02-08-2026 | 06:05 PM
  #648
Monotremata's Avatar
So does that mean, if I decide to buy one, they wont pull an Associated and release a LD3.1 or LD4 2 weeks after I buy it?
Monotremata is online now
Old 02-09-2026 | 01:09 AM
  #649
Pistol123's Avatar
Default PB Rear Hubs on Astro
Does anybody have any experience of running the PB rear hubs on dry astro. I see they are using them on carpet and I don't like the faff of changing the ld hub inserts, also fancy trying UJ driveshafts - so thought I might try both at the same time as the pb hubs need the PB driveshafts.
My only concern is the pb hubs are narrower and I prefer the H hub inserts (wide) in the dry to provide more on power steering compared to the M hub (narrow) set. As you run a wider hex for the narrower hubs (in my mind the distance from the wheel face to the outer wishbone pivot is the same)is it just the top link length that is really changing?
Thanks.
Pistol123 is online now
Old 02-09-2026 | 01:12 AM
  #650
Pistol123's Avatar
Everyone I have asked believes there won't be a new car until Sept 2026 as there is usually a year between 4wd and 2wd new cars. But who knows.
Old 02-09-2026 | 03:17 AM
  #651
That's the thing with Schumacher - they don't faff about pre announcing stuff or doing long build ups. They just say "Here's a new car, all the dealers will have stock in a couple of days, job done"
Hopefully whatever comes next in 2WD will have the rear pill system from the CAT PB and an improvement to the front kickup plate (or a one piece chassis with kickup).
5 gear (or 3 gear with a massive idler gear) would be nice on carpet car, but I'd expect it to be moulded plastic rather than the new 3D printed aluminium one.
I pray they will ship a car with better shock caps - it's the first thing I have to swap on every Schumacher.
Old 02-09-2026 | 09:47 PM
  #652
Taz_S's Avatar
I see them coming out like last time with a Storm 3, to work out the bugs before the LD4 come out. Would love to see a Dirt and Carpet for the Storm. if they can come out with the stiffer arms that would be very nice.
BuggyFan21 likes this.
Taz_S is offline
Old 02-13-2026 | 05:06 PM
  #653
ChadoSan's Avatar
Monotremata likes this.
ChadoSan is offline
Old 02-13-2026 | 05:07 PM
  #654
ChadoSan's Avatar
Really hard to fit a fan with the 5 gear trans. Had my battery back one notch before and the fan hit the battery and the motor.
ChadoSan is offline
Old 02-13-2026 | 05:45 PM
  #655
Had to do a double take, that slipper spring looked so weird tightened all the way down, couldn't figure out if that was part of the gearbox case or not.
Old 02-14-2026 | 03:47 PM
  #656
ChocoTaco73's Avatar
R/C Tech Elite Member
An ST2 topshaft will take care of that
ChocoTaco73 is offline
Old 02-16-2026 | 04:18 PM
  #657
ChadoSan's Avatar
Good idea I think I have one some where.
ChadoSan is offline
Old 02-17-2026 | 06:26 AM
  #658
clinttredway's Avatar
For those that have tried the new 5 gear transmission, what are your thoughts compared to the 3 gear?
clinttredway is offline
Old 03-09-2026 | 06:07 PM
  #659
I am curious about the 5 gear as well. Especially with 17.5.
Rfury is offline
Old 03-10-2026 | 08:43 AM
  #660
CGS
Tried it for a while on carpet/17.5, felt more edgy but the LD3 felt a little smoother. But you would need to change your whole set up IMO. Super pricey for what it is…
CGS is offline
