Schumacher cougar LD3 >
Like Tree317Likes
Old 10-01-2025 | 10:42 PM
  #616
ChadoSan's Avatar
HOTROD716 likes this.
ChadoSan is offline
Old 10-02-2025 | 06:37 AM
  #617
HOTROD716's Avatar
Originally Posted by RCBuddha
Is it me, but the picture of Broc's car in the article looks what I think might be an aluminum lower/servo mount would have been. Realizing the servo is laying flat on the chassis. Very curious if this might be an update.
HOTROD716 is offline
Old 10-02-2025 | 06:41 AM
  #618
The lower bulkhead and other parts look like metal 3d printed prototypes. There are more photos on Schumacher's facebook page.
lagcisco, glenng and HOTROD716 like this.
baconracer is offline
Old 10-02-2025 | 07:20 AM
  #619
I hope they keep the 2 piece chassis
speed101 is offline
Old 10-02-2025 | 07:36 AM
  #620
RC10Nick's Avatar
Interesting to see that it's a fairly standard looking LD3 - no special standup trans, extra rear weights, or crazy amounts of rear arm sweep. Heck, even the battery is pretty far forward. I'd say that's proof enough that these new cars can work great even outdoors. Even if people want to argue Hills was "high grip", I don't think you can argue it's as high grip as any of the indoor clay tracks these cars were really designed for. Even Nate Sutherland in an interview said Hills was a hard track to make the jump from stock to mod because you've got to be way more careful with the throttle than running at a place like Hoosier - jump to 4:00:25 for that moment.
lagcisco likes this.
RC10Nick is offline
Old 10-02-2025 | 02:10 PM
  #621
https://www.youtube.com/live/-VNinpd...yVt9TT&t=14418
Looking at the angle of the driveshafts, must shorten the wheelbase quite a bit.
What an interesting curio these cars are... I still don't understand how they have all ended up there and that this was considered the optimal solution. Interesting to hear the Tebo interview where he was saying most of them look terrible to drive and unstable. I mean Davey Battas didn't, but I suspect this is talent related. Tebo was pondering how well his stand-up RB6 would have done...or cars from 2015 ish. Like, what was the design aim? I get they tried it with the B7 as 5 gear was the only option and that's a way of getting more weight to the rear. But Schumacher have the layback and chose to this route? Is it that the SWB and instability lead to quicker lap times...if you can hang onto it?.. Will we see cars get shorter now? I'd love to know what they tried and how they ended up where they did. For me, I thought 4 gear laydown would be worth a go. The XB2 with this was always a weapon on wet astro with this.
AntH3001 is offline
Old 10-02-2025 | 11:15 PM
  #622
Pistol123's Avatar
From experience of running a b6.1 on wet astro, I always found compared to the laydown transmission with the stand up you are just weighting and age for it to rotate. Using the laydown and rear arms more forward gave you the rotation and rear grip once it was straightened up.
Having said that the LD3 wet car is running the layback and still wants to let go a bit getting on power.
Pistol123 is offline
Old 10-03-2025 | 02:16 AM
  #623
Lonestar's Avatar
Holy crap Schumacher finally won the biggest offroad prize in the game again 38yrs after Masami's first showdown at Romsey...
CONGRATULATIONS !!!
Lonestar is offline
Old 10-03-2025 | 10:30 PM
  #624
Schwarta's Avatar
Pretty standard, except for a new rear block to incorporate the pills system from the PB and the flat mount servo.
https://events.redrc.net/2025/10/cha...in-schumacher/
Lonestar and HOTROD716 like this.
Schwarta is offline
Old 10-10-2025 | 04:32 AM
  #625
Pistol123's Avatar
Originally Posted by TobyStephenson
when you run the wide hub, you run narrower hexes, such as -2, to keep same overall width
take a look on petit for Ben Smith setup at Herts last year as an example. You do need the dirt inserts to achieve the “later” letter settings and depending on what you run, different length driveshafts may be required to retain correct engagement in the drive cup. I think it might be the dirt car UJs in this case.
Just circling back to this now I have played with the rear hubs some.
Initially I was running H (wide) and that was nice, I changed at a practice session to B Narrow and that was horrible, really locked in the rear and then was unpredictable when it let go.
Last time out I tried F (wide and low) as that was what a mate was running. Much nicer, rear end while freer was much more predictable, only comment would be it had a little too much on power steering and not quite enough turn in.
I think I will either go back to H or try F wide and high (as per Ben's Herts setup you suggested). I think for our track that may lock the rear in a little too much, I know at the National with the number of cars and layout change the sand came up a lot at the National so I can see F wide and High being good for that.
I think with the flat Mezzo tyre it's all about keeping the car flat if you need the rear grip or using the lower RC heights to allow the car to roll off the tyre tread a bit to free the rear end. Slowly getting my head around...I think.
Thanks for the help.
Pete
Old 10-13-2025 | 02:12 PM
  #626
ChadoSan's Avatar
Had so many spares I was able to put together a whole spare car. Lol
ChadoSan is offline
Old 10-25-2025 | 03:25 PM
  #627
Taz_S's Avatar
So what need to switch over the the pill set up??
Taz_S is offline
Old 10-27-2025 | 02:48 AM
  #628
Pistol123's Avatar
Managed to run the Wet car yesterday, in practice it was very keen to swop ends when getting on the throttle. With limited time until the first race I quickly moved the rear shocks in on the arm - wow the difference was amazing, so much more planted. Was running green spring with 2*1.8 and 350cst oil.
Old 11-11-2025 | 10:31 AM
  #629
Hello,
What are the options and spare parts I need for carpet / astro race in mod class ?
Thanks a lot
shiver750 is offline
Old 11-11-2025 | 11:12 PM
  #630
Pistol123's Avatar
Originally Posted by shiver750
Hello,
Thanks a lot
Eight meetings in with the LD3 in mod and I have only broken a front wishbone and yoke. For carpet I think you will want the alloy front (and maybe rear) camber plates and the steering bar. Alloy front yokes and hubs would also be a good investment for carpet.
