Team Associated B74.2 / B74.2D
#406
What is everyone doing for center diff vs. slipper on black CRC carpet for 13.5? A group of us are going to get the new CE 74.2 and get a class going here at our local track, just trying to decide how to set it up for 13.5.
Seems the CE comes with the decoupled slipper, but the AE lightweight drive bones say not to use with a slipper.
#407
Trying to get clarification of that but I believe it is the case that the plastic parts come with the B74.2D CE along with the centre diff, B74.2 CE having metal with the slipper .... but that is just my understanding , not gospel
#408
Thanks Roger
We’re running a large (40m x 30m) grass track again this summer season, fairly bumpy, most of us run 4WD outdoors.
Was going to get a D but don’t fancy it if it’s plastic internals with a 6.5 / 5.5 motor.
Wondering if the one way slipper might be more suitable anyway…always used to run one way clutches back in the day on grass. Thoughts?
The other thing I’m not clear on is what work/parts are needed to drop a centre diff into all the chassis hardware which seems to be necessary to run the one way clutch 🤷♂️🤪
#409
KPI front end on the 74.3 then...
#410
Does that apply to the one way slipper? No idea but It'd be risky it seems like. I might give it a try, but I might not. I picked up a schumacher L1R to mes with as I have an electronics sponsor not a chassis sponsor for that reason. So my 74.2 is shelved for a while.
#411
Thanks Roger
Looking at the installation I think that a sleeve could be made to go over the gear diff front bearing and outdrive to pick up in the new bearing location used by the decoupled slipper, would be a pain to fit though.
#412
Thanks Roger
Do you run centre diff on wet astro?
#413
Having not run the plastic gears I can't comment on them. I absolutely cannot drive a 4wd car on a surface with grip with a centre diff in, just totally incompatible with my driving style (as in 2s/lap off the pace of running a slipper). I'd always be running the slipper if there were dry tyres on the car.
#414
Seems like the chassis is out of stock everywhere. Bit concerning.
#417
What does the b74.2d weigh stock, ready to run? I know specific components can change the weight significantly, but just interested to see what you guys are seeing before you put the cars on a Weight Watchers diet.
My current car is 200g over the minimum and I am looking to get something a bit closer to the minimum.
TIA
TIA
#420
TIA
TIA
