Team Associated B6.4 and B6.4d
#1441
Most people don't run a front wing but try it and see if you notice and difference/like it but not essential.
Re the diff, best to take it out and eork out if uts a ball diff or gear diff. You are correct it should spin the other way when you hold the spur gear. If it's a ball diff, new balls and a rebuild kit should have you sorted.
Good luck.
Good luck.
#1442
Any one have any information on Schumacher springs? I have seen/heard some guys run them for carpet. I have a very light weight b6.4 and would like to try some different springs but don't know which ones to buy. For reference we currently run orange fronts and yellow rears. Want to try some slightly stiffer springs.
#1443
What you need is:
- the spring itself (CR811) - HR black spring (rate 2.6lb/in), that's the one people are using on the rear of the B7 a lot.
- if you want to go stiffer all around you'll want the yellow front springs as well: (CR636)
- the spring cup, the Schumacher springs taper at the bottom end (U4890)
Hope this helps, sorry I can't link to these yet as I don't have the required postcount yet to include links.
#1444
Has anyone tried the B7 caster and steering blocks on their B6.4? I tried it yesterday because I wanted the additional roll center adjustability available with the B7 blocks. While the parts fit directly without changing the arms, I did get sway bar bind on the compression stroke of the suspension. When I drove it on the track, the car was noticeably easier to drive so I want to stick with it, but I need to deal with the sway bar bind issue. Any thoughts? TIA!
#1445
If I recall people are using the B6.1-3 caster/steering blocks, this is to improve steering response? Can't remember.
I'm getting my B6.4D together for wet astro so thought stay on the kit 6.4 items?
#1446
For wet astro you will want the B6.1 castor blocks and steering knuckles, the car needs all the help it can get with turn in on the floppy Schumacher silvers
#1447
Been wondering what the fusion tyres will be like on astro too, not purchased any yet.
#1448
Odd question, but has anyone mounted T6 sideguards to their B6.4? I want to run a more traditional body (think rear cab like old school) but the one I've found is wider in the back. I've tried side guards from my T6.4 but they're too long; wondering if the a different T6 sideguard would fit?
#1449
#1450
What spares would you guys get for a B6.4 for carpet?
My kid broke the ball mount for the roll bar this past weekend, with the upgraded carbon arms. I still have the original plastic arms so I'll put them in for now, hopefully it's not the start of a trend breaking the bar mounts on the arms. He also somehow bent a front titanium tie rod..
#1451
#1452
Front arms, hinge pins and bulkhead tend to be what I’ve needed to replace. Carbon arms are tougher, but tend to bend hinge pins in a way they get jammed in the aluminum bulkhead. For reference, I have 3x B6.4s setup for stock 17.5 that my son and his friends use about once a week in the summer at an outdoor turf track. Everything else has been fairly durable. I’d also grab shock x-rings and diff seals to have on hand for rebuilds.
#1453
Hi all,
I'm looking to convert my old B6.4 to a wet astroturf car so i want to add a standup gearbox, but cant seem to find a list somewhere with the parts to do so.
Is it the b6.2/3 gearbox and internals?
#1454
Good luck.
#1455
