Tekno RC ET410 Thread
#1351
#1352
Personally with them having maifield I was hoping this could mean a revision to there 1/10 4wd buggy and a 2wd buggy being released ...
#1353
#1354
Does anyone know of a conversion kit to allow me to run a taller battery in the ET410.2 (3s or 4s lipo)?
The closest I have found is:
https://modspeedshop.com/collections...-eb410-2-18013
but don't think it is compatible for the .2. There isn't a spot in the chassis to attach both brackets.
#1355
#1356
The only thought i would have on running a taller batter (does a shorty 3s even exist in a hard case? I know 4s does) is to find a way to ‘thread’ a 1/8 velcro strap into the servo mount and behind the rear battery brace. The strap should be long enough if there is room enough in the servo mount. The rear battery brace screws in from the bottom so you should be able to clamp the velcro between the brace the chassis to lock it in.
just a thought. I am un aware of any produced larger battery hold down
#1357
You most certainly would have to go with another body that doesn't contour the rear tapered part of the chassis.
Edit: Anything other than a shorty and you'll have to stand the batter on it's side to clear the center diff.
#1358
The 410 has a small battery compartment (only fits a shorty pack. there is not enough space for a standard battery box (red rectangle shows the battery area) if there is a shorty battery box the only attachment point in the chassis is the rear post of the battery area.
#1359
Rusty-
Re-reading your post I think you are right, one could cut the body and have the tray stick out past the tapper, not sure how protected the battery would be, but a shell tat fit that would look pretty old school, I think I like that idea
#1360
I don't know why I'm even entertaining someone else's notion of putting a normal size 3S LiPo pack on a ET410 chassis. The center diff is the obstacle. A person would need to stand the battery pack on it's side to clear things.
#1361
469Likes
. Actually, it would be insane for me on 2S.
