Tekno RC ET410 Thread
#601
I decided to move two of the front axle washers to the rear of the hinge pin shaft, the thick and thin one, and leave a thin one to the front. This should extend the wheel base and smooth out the steering. Shorter wheel base cars turn very fast.
#603
I opted for a 3900KV 4 Pole from Novak and that's working very well for me with a 20T pinion. I originally started out with a 5.5T 2 pole motor and while I was happy with the performance, the motor thermaled on me after 4+ race days. Most folks in my area are having good luck with 6.5T 2 pole motors.
I tried out a TenShock SC211-4400KV and couldn't get that motor to last a single race day... I found out yesterday from another racer at our club that he couldn't get 1 pack through his SC211 before his motor burned up.
#605
Are any of y’all bending inner front hinge pins? I literally bend one every couple of packs, oftentimes taking out an arm or the pills. Am I the only one?
Which is weird because I rarely break anything on any of my other kits, including my EB410.
Getting frustrating, and I wish I could just chalk it up to bad driving, but I’m really not that terrible of a driver, honest!
#606
#607
I've bent a few pins already as well on a clay track. It makes sense to me. Think about how people were having problems bending EB410 pins on carpet, and then imagine all of the extra traction generated by ST tires, and all of the extra load applied by the longer arms and track width. Granted, all of my bends have been from bum landings and tumbles thus far. Right now, I'm at an all time record with this thing... 3 race days and no breaks!
What sucks is when the pin bends it destroys the insert and wallows out the hinge pin hole in the arm... so it immediately requires replacing 3 parts.
#608
Also, I just now noticed that the paint on my rear half shafts has started to come off about half way point (on each side). It looks as if somewhere in the travel that the shock springs are brushing against the half shafts. Did I mess something up or has anyone else had that happen? What would be the best way to fix that w/o messing with set-up? I assume it's easier to shim the standoffs to bump the shocks out rather than reshuffle the spacers that are on the pin/arm (which would slightly change wheelbase, I assume)?
#609
Thats what I run and it has been great.
#611
Just stuck the M3 5.0 motor in this and at first it was slow, so I punched the timing up on the RSX to 35* and now it looks good. I guess I need to check out the rear shocks for rub. Added some weight to the rear.
#613
First run with the Tekin 5100kV Pro2 motor last night, and wow, this thing rips! Started with a 16t pinion and motor temps were just over 100 after 10 minutes, 17t brought that up to about 110, ended with an 18t and temps still low at 115. Running kit setup with 30/30/10 in diffs and no problem with front liftoff down the straight, very responsive to throttle attitude adjustments in the air. Pushing a bit on throttle in the corners and plan to decrease front, increase rear sway bars a bit; the track is short and pretty tight in the turns.
#614
that's crazy that you're getting an on power push with the kit setup. what type of surface?
i'm trying to tune some of my on power steering away. i went to 20 in the front and 50 in the center with orange front springs, and for me, it's much easier to drive.
#615
469Likes
