Team Associated B6.1 & B6.1D thread
#3646
In theory, would a dirt setup (ie. Spencer's go-to setup that he was using forever) be easier to drive on carpet for a 6 year old (lazier response)? Or more difficult when compared to my carpet setup (setup for max speed and not necessarily ease of driving)? Wondering if I can dual-purpose my dirt car for him, since he only races novice once a month or so on carpet. I would put the gear diff in for him, lower the ride height, and send it, vs buying another car.
#3647
What kind of handling characteristics change between the flat and gull-wing front arms? (using the correct towers)
#3650
Last year at the Midwest champs race at The Ohio RC Factory I copied his setup because I run at that track and I really liked it, I guess copying a setup depends on how close your driving style is to his and how similar the track conditions are, I copied a setup before from a track in Cali and hated it in Ohio.
#3651
With the flat arms there is a lot of initial tyre loading (which is what produces grip) as the shock is initially quite stiff but as the car rolls there isn't much change in the stiffness so the grip level doesn't increase, if anything it will drop off.
That is why you get that feeling of initial steering then a tendency for increasing push as the corner progresses
The gullwing arms give a fairly soft initial feel due to the car being able to roll relatively easily at first thus not loading the tyres but as the car rolls and the suspension compresses the shock angle changes causing the shock to effectively stiffen which in turn loads the tyre more resulting in more mid-exit steering.
Now here is the caveat, this relies upon the effective line between the inner and outer hinge pins being relatively level, certainly not sloping down towards the chassis very much, if it is you will still get a slight gullwing effect but no much.
To get the gullwing effect you need the shock mounting mount needs to move outwards as the car rolls away from rideheight.
#3653
#3654
Generally yes, start with the same shock package between the tow arm types, then if you need to tune to suit you / the conditions.
#3655
I have a question I figured I ask here even though it is not off road related I figured there is enough fast guys here that could help. We are racing our B6.1's on carpet for now and will be outside once it starts, and it is oval for both. they are Modlites, the cars are fast on carpet cant wait to get it on the high bite clay oval. Any ways my question it would a gear diff be better than a ball for both and would a slipper or slipper eliminator be better. Please explain the answers so I can learn something rather than just be told do it this way or that.
#3656
#3657
#3659
if everything moves freely, but then only briefly tightens up just a little, then releases again, it is probably one of the internal transmission gears that is a little out of round. if i had to guess, it would be the idler gear. i just went through this on my tlr 22-5.0. i bought a pack of two idlers. the second one fixed the problem. just my experience.
#3660
Sometimes it happens when you overtighten screws, try checking the lower 2 screws holding the two halfs of the case together, or the 4 screws that clamp the top cap of the transmission on. They do not need to be clamped down real tight, just snug or a 1/4 turn out from tight can free it up. Try twisting the case back and forth while you loosen them if you have it out of the buggy.
Another way it can happen is if the aluminum camber plate is not aligned fully into the slot on the rear of the transmission case. I think Roger has a post on this.
