Sydney Model Autosports Inc [smaracing.org]
#4189
Originally Posted by dee_vee_eight
If you get too quick we may have to clip your wing/s
#4190
Sunday Fun
I had a lot of fun out there today. Nitro was an absolute blast and it was difficult trying to run two classes. Overall i was pretty happy to finish second in Stock (from fifth qualifier).
A big thanks to to all that helped me today with my nitro, especially Adam, Mark & AJ. Got some good laps in and now i just have to be consistent and play around with the two speed to get second gear to kick in. Craig and i had a fun final in novice and it is now time to step up. The TZ is a fricken rocket.
A big thanks to DW for running race control.
BTW, the Greg Still cup is currently residing at my place and it looks quite at home .
It could have been a good day for Corally but HI choked. Congrats to Martin for a good win (it is good to have clean air) and it is now a very tight point score for Stock.
Thanks to HI and Darren for putting up with the noise.
#4191
Man i gotta pull my finger out if im gonna keep up with you guys .. Big mention to Michael Rumiz. Damn he is quick ! Gave Lally a bit of a puckering .. lol
#4192
Andrew, were all going to have to pick up our game, you were on fire yesterday!!
Everyone seems to think if i'm this quick with a 710 i could be even quicker with a 720 Only problem is i'm too poor to afford a 720
A HUUUUUGE thanks to steve, when i blew both bearings in my clutch he gave me some replacement ceramic bearings What a dead set legend!
#4193
Celamics ! Whoahw !
#4194
#4195
Man dont touch your clutch set up , it was hummin nicely ..
#4197
XRAY quality Vs HB
Yeah sorry I missed out had a cousin’s birthday party but hopefully I will be there next time. I am still trying to figure out this motor fade problem that I was having on Tuesday night.
#4198
Andrew leave it, i'm pretty sure the engine just needs some more leaning, so it makes enough power to engage second. Its not the 2speed "gap" that determines when it engages its how tight the springs are
Depending on the turnout next meet, i think it'd be better to run 2 heats of nitro rather than the pro/novice setup. It'll give the quick guys a bit more space (heat 3 was pretty hectic!) and it'll give the faster novices a chance to make the A-main - not that pitting for 2 guys wasn't fun or anything
#4199
Originally Posted by astra power
You're confusing the clutches, the 2 speed changes depending on the speed of the drive shaft (as opposed to the engine) so leaning it wont do much beyond getting it to the shift point a little quicker. The tighter the springs in the 2 speed are the greater the gap between the shoes and the bell, but it's best to just take it somewhere with some space and experiment. Spot on for me is considerably tighter than the instructions recommended but even then i only hit 2nd at the end of the straight when it's time to turn in.
No spring do not adjust the gap, there are specific grub screws with the mugen that adjust the gap! The gap should be set at a certain point and left, from memory mugen said to tighten the screw until the shoes drag on the bell and then back the screws off a 1/4 or 1/2 a turn.
The more power an engine makes the easier its going to shift into gear, i've had A LOT of experience with this at moorebank i have an RB that will only just grab second gear whereas my TZ rips into second gear in the same car. I talk from experience of what i know works.
You don't need 2nd gear at tempe if your engine revs high enough then just tighten the screw until second gear doesn't engage, heck i was passing people down the straight and i didnt have 2nd engaging.
