England Park Raceway, Brendale.
#6616
Don't everyone nominate at once! .... geeezz
#6618
#6619
Ole Tez used to go pretty good in a GT.
#6623
After that there are a few other things to try if you are still having issues. If you like, at the next race meeting I can walk you through some of the chassis settings and set your car up to handle a bit better.
The traction rolling may have caused you to chunk the tyres. Once you have the car setup you may find that the chunking will stop. If not, using the tyre saving stickers, if they come with your tyres, or running some CA glue around the outside of the rear tyres will help.
Hope that helps.
#6627
Having said that, check that your shocks are built consistently (each of the front pair have the same rebound and no air in them, same for the rear pair). Check your sway bars are set up correctly and that your droop settings are equal, side to side.
If all of that is okay and you are still having traction roll issues there is a big list of things to try, but i would start with a harder rear tyre and widening the track front and rear. After that I would look at raising the roll centres to try and stop the car pitching as you turn in.
This is what I would do, but others may have differing opinions or suggestions. Traction rolling is an infinitely debated topic (do a search in the EP on road forums to completely confuse yourself) and every body seems to have their own approach.
#6628
Then connect sway bars, check again, adjust as needed, then reset everything to the suggested OEM setup that came with the kit, once you all at stage zero, then you can move onto to adjusting one thing at a time to work at one problem at a time.
Generally most the kits being sold today come with good setups out of the box, but attention to detail is everything when it comes to making them work, also making sure all your droops and travels are working right with tyre diameters is very important with the foams.
#6630
Setup for Heartostone
Heartostone I was running this chassis when I first started SSF. I will dig up my setup that I was running and PM it to you if you like. I only ran the car for a short while before switching to Xray. But I had the car dialled in pretty good and am only to happy to share the setup I ran with you.
GC
GC
