Tamiya mini thread
#121
Originally Posted by Dan the Man
Anyone know of an Australian store that can get a set of mini rims to me in Perth this week? None available here
#122
#123
Originally Posted by tony gray
Buy the M like Cannon said. You can always pull the centre spacer out and run it as a SWB (like several people did at the VORTEC Titles on the weekend)
And you also get the bonus of the new toe-in rear uprights and the new front end. Which means you dont need to buy new rear uprights or the horribly expensive alloy front ones.
If you run it as a SWB you can also get a lot of inexpensive bodyshells, MWB and LWB you cant.
#125
Can anyone tell me if the CVA mini dampers are the same as the CVA dampers in the TB02 kit (both plastic oil dampers). Fully extended, the TB02 dampers are about 3mm longer then the friction dampers in the kit.
The other question is are they TCS legal?
Cheers.
Cheers.
#126
I think the TB02 uses "Mini CVA "shocks. The "Super Mini CVA" shocks have a shorter shock body and are easier to use on a Mini. If you use internal spacers/o-rings to shorten the overall shock length on a CVA shock it becomes increasingly difficult to install the spring retainer. Just my .02c worth
#132
Thanks for reply.
We do run TCS rules + any tyres.
I`m using TRF shock OP-571 and high torqe servo saver SP-473.
Can not find them on my manual so they are illegal??
I know my club don`t care but I like to keep`em all TCS legal.
#133
Mini rules are as per TCS rules and the accompanying appendix. Failing that the Tamiya Guide book will show you all the standard parts and optional parts for your specific model. Some early M03 manuals(I think the Rover Mini Cooper) were incorrect.They nominated 22/23T and 24/25T pinions as optional and as I found out the hard way they were declared illegal. Wnjoy your reading!
#135
