Team Magic E4
Old 02-13-2008 | 12:24 AM
  #91
bender's Avatar
Originally Posted by Nitrobuggies
Great steering although stock set up i found it would push slightly mid corner (although the driver did remove the plastic cross brace for some reason) i think it gave to much flex. I had to slow right down mid corner, but found entry and exit to be great.
I finally got to race mine last weekend and found the same - great turn-in and exit steering but a bit lazy mid corner.
On my local track, this was only a slight issue on two corners, but on all the tight stuff the car was ballistic
I raised the inside front camber link by 2mm which seemed to help.
Broke my personal best race time in the second race (retired from the first race with a dud motor) and set 7 new fastest laps.
The drivetrain has loosened up nicely now, though I did raise the front layshaft bulkhead by 1mm which loosens both the front and middle belts.
bender is offline
Old 02-13-2008 | 01:58 AM
  #92
OLD 69's Avatar
Company Representative
Good to hear others having good results with the E4.
For those after the E4 FS version, there will be a wait as there are none in the country and team Magic is out of stock too.
...Ari
OLD 69 is offline
Old 02-15-2008 | 04:36 AM
  #93
Has anyone else had any trouble with the servo saver on their E4??? Mine decided it didn't want to live anymore and detonated tonight, the spring ejected at mach 2 and I lost one of the spring "caps" off the end. Now it doesn't go back together properly... NOT HAPPY! on the positive nothing else on the car broke when it slammed into the wall.
$$$... is offline
Old 02-15-2008 | 02:43 PM
  #94
Mad Mackem's Avatar
I tried for ages to get the servo saver together but gave up in the end and used a different one.
Mad Mackem is offline
Old 03-13-2008 | 08:19 PM
  #95
Marcos.J's Avatar
Super Moderator
As for springs you can also use Tamiya (short) springs! Losi Type R also woerk very well.
Marcos.J is offline
Old 03-13-2008 | 08:20 PM
  #96
Marcos.J's Avatar
Super Moderator
front camber link semms to have a very good sweet spot with a 3mm shim
Marcos.J is offline
Old 03-14-2008 | 12:28 AM
  #97
bender's Avatar
Marcos,
You don't have part numbers and spring rates for the short Tamiya springs do you?
I've got TRF shocks on my car simply because all the springs I have are too long for the kit shocks.
bender is offline
Old 03-14-2008 | 01:42 AM
  #98
ShadowAu's Avatar
I broke my first drive shaft last weekend... it was in an impact with another car that crashed in front of me so that probably had something to do with it... I am hoping the new 7075 alloy ones don't break
Setup on mine now is still close to stock - 1.3mm front sway bar, moved front top arm to outer hole on the bulkhead... still using the factory springs... this setup calms the steering a little on my track but still gives plenty
ShadowAu is offline
Old 03-15-2008 | 06:38 AM
  #99
zacabrandy's Avatar
Just want to know what the difference is between the E4 and E4RS and which one is the higher end chassis, or better buy?
Also what is the point of the 2 chassis?
Where is the best place to buy one, would probably be looking a 2 so would want some good pricing?
Cheers
Aaron
zacabrandy is offline
Old 03-15-2008 | 04:27 PM
  #100
blue hornet.'s Avatar
anyone who has known me for some time
blue hornet. is offline
Old 03-16-2008 | 01:49 PM
  #101
ShadowAu's Avatar
Cheers
Aaron
I believe the RS has been released to clear up some of the "problems" and suggestions from the original E4... different (plastic) belt pulleys, different drive ratio, different top deck mounting for easier lipo fitment, easier motor fitment, motor cooling slots/ducts etc
As for performance on the track they would be pretty similar I would think as the geometry and layout is almost identical
ShadowAu is offline
Old 03-20-2008 | 05:17 PM
  #102
Marcos.J's Avatar
Super Moderator
Marcos,
Tamiya short rating:
White-17.54 lbs
blue-15.69 lbs
yellow-13.99
red-12.35
TAM53630: Tamiya Short On-Road Tuned Springs (Red)
TAM53631: Tamiya Short On-Road Tuned Springs (Yellow)
TAM53632: Tamiya Short On-Road Tuned Springs (Blue)
TAM53633: Tamiya Short On-Road Tuned Springs (White)
Marcos.J is offline
Old 03-20-2008 | 10:21 PM
  #103
zacabrandy's Avatar
There'll be 2 more maybe 3 more E4's doing the rounds in Sth East QLD soon. Placed our order, now just waiting for the goodies.
Cheers
Aaron
Old 03-21-2008 | 12:43 AM
  #104
zacabrandy's Avatar
What brand spur gears will fit the E4?
Old 03-21-2008 | 02:50 AM
  #105
ShadowAu's Avatar
Pretty much all the usual brands will fit
ShadowAu is offline
