Team Magic E4
Old 01-06-2009 | 07:50 PM
  #136
I have been having a play with an E4 RS, it has some great ideas, but also some teething issues.
Quite a few of the teerthing issues are being solved, and many of them have been rectified in the 2009 model.
A big point to note, is that some wheels will hit the front arms under steering lock, all you need to do is add 1.5mm of spacers at the hex, and 90% of wheels should clear, it will look on the bench that they dont hit, but when running it hits, and will cause the car to hop in the corners. Its not a biggy considering out of the box the car is so narrow, i think mine was in the very low 180's
Check the outdrives rotate in the axle cups smoothly, for some reason one of mine was binding the suspension, i swapped them left to right and all was ok.
Check that the shocks do not bind, mine the pistons were a little tight in the shock bodies, i just put the shaft in a dremel and polished them down a little on some very fine wet and dry.
Besercoe is offline
Old 01-07-2009 | 08:53 PM
  #137
mild seven's Avatar
Just got my E4 today, woot. opened the box and to my surprise the car was already pre-built I guess it saves me doing a build review for the website
mild seven is offline
Old 01-08-2009 | 07:38 PM
  #138
mild seven's Avatar
Here is a pic of my E4, all ready to race now.
Old 01-11-2009 | 02:54 AM
  #139
mild seven's Avatar
I raced the car for the first time today. I'm very happy with it. i started off with Jake Zarbs setup from the sydney gp and played around with different springs, droop and shock positions on the shock tower. The car feels a lot better now, more stable but still has lots of turn in.
Only thing i changed from Jakes setup was:
droop, now 4 front, 3 rear.
Hara purple springs all round,
1.4mm stabilizer bar on the front,
2nd shock position on the front and the middle position on the rear (i think its the 3rd hole) also i was using 40wt oil
cheers
Tom
Old 01-21-2009 | 05:47 PM
  #140
Default TEAM MAGIC E4RS 009
Hello All
TEAM MAGIC E4RS 009's Arrived Yesterday and are ready for shipping...
TALK TO YOUR LOCAL HOBBY SHOPS>>>>
ZauberRacing is offline
