New Novak Brusless System
#676
Marcos did you ever thermal your GTB at the last Superior race? If you did, did you happen to checked the temperature? I need to know how far I can push it before it shuts down. Oh, if you find another 4.5 I'll be glad to get it from you. My LHS's distributor won't have it till mid March
#677
Super Moderator
#678
Super Moderator
#679
Just so y'all know, www.rcboyz.com has the 4.5 in stock, I just got mine, holy cow, I almost cried only they were tears of joy!!!
#680
Hello all. Has anybody tried the 4.5 with the sphere competition? Do the "sensor" wires/plugs work? thanx
#681
I've asked this question before, but got no response, so here it is again, hopefully Charlie will pick up this time...
Does anyone know if there is a shorter wiring loom for the GTB? I run mine in a T2 and only need about 3" max and while I'm happy to shorten the motor wires, the harness is a different animal.
Also, if it's not possible to get a shorter version, could I wind the harness "around" the shortend motor wires to keep it neat and tidy?
Dave
Dave
#682
#683
Mate....
mail Charlie yourself... Maybe you'll get a more direct answer than you'll get from a bunch of end-users on a forum. I don't see any problem with wrapping it around the motor wires though. Nothing that wouldn't be beneficial. In general, wrapping the wires will only reduce the amount of interference pick-up.
I "folded" my wires into a length around 4cm long and slipped a piece of heat-shrink over it to keep it tidy and tucked away. I'm not sure whether actually shrinking the tubing around the wires would be great though. Probably too much of an acute bend.
I didn't spot the sensor harness being sold as an accessory on Novak's site.
#685
Brushless setup
I just put a GTB and 4300 in my 1/12 scale, because my local carpet roadcourse track is going to allow them to run with stock, until we have enough for our own class.
Does anyone know what program is best?
Are there any advanced settings that need to be changed?
What rollout should I run, if I normally run 1.75 with a monster?
#688
Originally Posted by AdrianM
It works just fine. All the sensor connections are standardized.
#689
WooooOo...
A friend has just come back from HK with a 4.5R. Going to give it a run on friday so we'll get a side-by -side compario with a 5.5R.
We'll have enough space to completely wind out the motors. Perfect flat concrete for at least a hundred meters in every direction. Baby smooth.. lovely.
Can't wait... too bad they rna out of the 4.5R motors in HK.. just the bundle with the GTB around atm...
#690
are the brushless motors louder than brushed motors?
