Xray XB4 thread
yes not to keep dirt or debris out but to keep the pins in, the shielding is an added benefit.
so yes run shrink rap over the joint (be sure to make the shrink rap go over the barrel a bit so when you shrink it it locks on. and also use dry lube in combination. i clean mine out maybe once every 4-5 days at the track (on clay - way less on carpet) and they could go longer but they get a tiny bit gritty.
Is the 2015 B4 Center Diff different from the 2016 or is it the same...?
I haven't had an issue with the pins coming out yet, but will try the shrink wrap to tip to prevent it from being an issue. My biggest concern is with the pin & barrel wear that I'm seeing - pins replaced twice and barrels once. I am only driving it on loose dirt and cleaning/greasing every other race day (with no other use on the car). I'll try the dry lube to see if it works better than the marine grease.
i've had mine in for 8 months and the only wear i see is the brownish coating, which isn't even worn all the way off. still original pins and barrels.
def try dry lube and shrink rapping them.
I'm running a 6.5T motor with an RSX esc with the current limit/Torque setting on 2 with no boost or timing added. The surface I drive on is on the loose side so this wear seems excessive as I can get a set of tires to last for a series/season or two
The issue is the pins have flat spots on them where they make contact with the barrels and the barrel holes are elongated from the pin contact. Initially I just replaced the pins, but noticed the barrel pin holes were growing so I replaced them as well.
also i run a 5.5t motor on high grip carpet and med-high bite clay, so i have way more torque going to mine than you do. my guess is it's the grease and the loose dirt doing the wear.
Try hosing them down with 100% silicone spray every run. It's a dry lube, when it dries.
Drive train wear is a constant in offroad. If you're eating Xray drives often, I'd hate to see how quick you can wear out an AE or Losi dirvetrain.
You may have also left the pins in too long. Once the pins show wear they need to come out or they eat the barrel.
That being said, I've nearly worn my XB9 center front CVD to destruction. But it's still hanging in there. That one's a PITA to replace, and I have an entire spare drive set, so I'm really lax on replacing it.
mine have just worn the coating off, but no actual deformation of the metal itself, so i keep running mine even after 8 months. my drive pins need to be replaced more often than that though.
also when you say barel do you mean the barrel insert, or the outside cage like barrel. i think the term barrel is meant for the ones on the inside.
when you say show wear you mean deforming of the pins right?
but mine have also been dry lubed and shrink wrapped. im willing to bet its wear from dirt getting in the grease.
Im going to switch the car up and put brunos setup on it for our carpet-astro tracks. I have a turnbuckle tying the spur gear area to the back of the car together acting as a too deck-any idea why besides stiffer chassis? How important is it to balance the car?
i was gonna say the inner barrels actualy come factory with an oval shape so note that. but ive never had flat spots on my outer cages. mine are fine after 8 months.
I use offroad bike chain lube from time to time, but mostly I like to keep my driveshafts clean in offroad. I am running the regular ones though.
molybdenum disulfide only use this
Is there a way to change the final drive difference from front to rear?
