Like Tree248Likes
Xray XB4 thread
Old 04-22-2016, 03:40 PM
  #10906
Originally Posted by billsharp34
Are you running that in a stock class or with mod cars
It's in the 13.5 only class
4s losi is offline
Old 04-23-2016, 07:15 AM
  #10907
Zerodefect's Avatar
Has anyone switch to Jconcepts 60mm wheels/tires for indoor dirt? Wondering which 12mm hex hubs would give the car about the same width, or 1mm more with these wheels?
http://www.amainhobbies.com/rc-cars-...o3368w/p360095
http://www.amainhobbies.com/rc-cars-...o3363w/p360085
http://www.amainhobbies.com/rc-cars-...50339?v=449515
http://www.amainhobbies.com/rc-cars-...54480?v=449523
I don't care if the 12mm hubs are Exotek, Xray, or JConcepts brands.
Zerodefect is offline
Old 04-23-2016, 04:12 PM
  #10908
Trader Rating: 11 (100%+)
Is anyone running a 13.5 motor if so what is your gearing and what is the max pinion you can put on with a 75 spur
Boom Rc makes a great one that is cheap and not only covers the steal chassis but the plastic side braces as well
Attached Thumbnails Xray XB4 thread-12821492_1078738772167531_5618306206579608590_n.jpg   Xray XB4 thread-12795374_1078884358819639_2806870729199628210_n.jpg
randy0025 is offline
Old 04-24-2016, 01:26 AM
  #10909
Originally Posted by lyons238
I just bought that hudy servo horn too. what can we do to stop these horns from rubbing the body?
Make your own
I placed a 3x8mm screw in the horn, used that as a guide and ground the horn down. Polished with a dremel and then got some sharpie to it.
He sharpie will come off I'm sure, but it's the right size now!!
cplus is offline
Old 04-24-2016, 07:55 AM
  #10910
Zerodefect's Avatar
Are the Xray shocks the same 12mm bore as AE/Yokomo/TLR? I'd like to test some different shock pistons.
Are the shafts the same diameter as well? I think they are.
Old 04-24-2016, 07:58 AM
  #10911
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Schelle offers AE/TLR and XRAY specific pistons...so I would say no they are not the same size. A buddy that has an XB2 also told me they were different, don't know how though.
Matt Trimmings is offline
Old 04-24-2016, 08:28 AM
  #10912
Suspended
Trader Rating: 61 (100%+)
Same OD.
However, the thickness of the piston is drastically different.
Socket is offline
Old 04-24-2016, 09:05 AM
  #10913
suzukipro's Avatar
Trader Rating: 33 (100%+)
Curious if anyone else notices that the ECS shaft 2x9mm pins wear fast? I'm noticing slop with the inside pin (closest to the outdrive) after only 4 race weekends.
I'm hoping it's just the pins wearing and not the coupling too as that will get very expensive to maintain going forward. I'm using a moly based black grease on these and wonder if anyone has a better recommendation to keep them lubed and increase life span of parts.
Thanks,
suzukipro is offline
Old 04-24-2016, 09:16 AM
  #10914
Zerodefect's Avatar
Will last longer in your bearing and on the CVD's. Your CVD's will need pulled cleaned and regreased just about every other race day. I pull a CVD whenever I'm bored in the pits. The Marine grease lets you wash the car off as well, which is handy.
I only needed the outer diameter of the shock pistons. Thanks. I'm going to try the AE/TLR shock pistons that VRP makes.
Old 04-24-2016, 09:28 AM
  #10915
suzukipro's Avatar
In my old profession we used to use mobile red synthetic grease for everything until our DC tool manufacturer trained us on repairing the angle heads and gear units on high torque DC tools. They recommended moly type grease for it's superior wear properties and would void their warranty if it wasn't used.
This line of thinking has always led me to purchase moly grease to use on my RC stuff for it's perceived improvement on wear items. I also thought the major RC companies supplying a black moly type grease with their kits were on to something as well (not saying I'm right though).
Old 04-24-2016, 09:53 AM
  #10916
Zerodefect's Avatar
The generic black moly I've had in kits is great for sliding, and flinging off when dirty. It's designed to flow. Great for low rolling resistance cold bearings. Something RC'ers used to be obsessed about. But I find that it dries out and wear off too quickly. Usually it's best for applications that are sealed up, like a gear box or tool drive.
But our CVD's are right out in the open. The Marine grease hangs around longer. The Red and Tacky flows better, and the CAT HD has moly in it if you still want that.
Grease is cheap, and cars have 4-6 CVD's, so it's easy enough to test each lube side by side.
Old 04-24-2016, 10:14 AM
  #10917
suzukipro's Avatar
I'm off to buy some marine grease, let the side by side trial begin .
Old 04-24-2016, 06:36 PM
  #10918
Trader Rating: 13 (100%+)
good info on the grease guys, thanks.
punkracer24 is offline
Old 04-25-2016, 03:28 PM
  #10919
Oh Qrap's Avatar
+ YouTube Video
Oh Qrap is offline
Old 04-25-2016, 06:14 PM
  #10920
Trader Rating: 15 (100%+)
X-ray pistons are slightly larger than AE/TLR pistons, they are not interchangeable.
HeavyD99 is offline
