Mugen MTX-4
Old 06-04-2007, 07:26 PM
  #8596
wallyedmonds's Avatar
Originally Posted by madbeats
2nd MTX4
sweetyour not gona run that are you.
wallyedmonds is offline
Old 06-04-2007, 10:38 PM
  #8597
asw7576's Avatar
Don't fight over 24T vs 25T ...........
I'm using 25T and 21T brake pulley !!!
asw7576 is offline
Old 06-05-2007, 12:19 PM
  #8598
madbeats's Avatar
Default pic's of the chassis
I think am going to give it to a friend of mine's... he is trying too get back into the sport.here's some pic's of the chassis
Attached Thumbnails Mugen MTX-4-mtx4-b.jpg   Mugen MTX-4-mtx4c.jpg   Mugen MTX-4-mtx4t.jpg
madbeats is offline
Old 06-05-2007, 04:45 PM
  #8599
LogiK's Avatar
Trader Rating: 11 (92%+)
Ok, got a few questions
1. What is the performance different between all the pulleys.
2. How do you go about replacing the tank and a rear belt (dont wanna more than needed)
3. What are some makeshift things I can use for checking my chassis setup .etc?
4. And what are "Active Speed" foams like?
Thanks,
LogiK
LogiK is offline
Old 06-05-2007, 05:48 PM
  #8600
Trader Rating: 45 (100%+)
Has anyone on here tried using the front diff. setup that came with the car? I went and got all the extra parts needed to put it together like the manual stated...but in doing so...it doesnt seem to fit.
#1. It seems it is too wide..and the bearing/hub rubs on each side.
#2. The steering rack hits the diff. case.
Please tell me there is something I am missing here...as I have looked over the manual a dozen times.
Derek
kaotickc is offline
Old 06-05-2007, 06:01 PM
  #8601
rmdhawaii's Avatar
Derek
Did you use the correct diff outdrive? The fronts and rears are different:
Front: T0202 Diff Cup Joint
Rear: T0261 Diff Cup Joint
Also what Ackermann insert/position are you using?
rmdhawaii is offline
Old 06-05-2007, 06:35 PM
  #8602
rizal_eg9's Avatar
Derek
I think the problem is with the diff pulley....if you are using one way...there is a plastic piece which you need to glue it to the pulley but you can't glue it if you are using the diff or spool.....if anyone got an exploded diagram....it is easier to pin point the part.....
rizal_eg9 is offline
Old 06-05-2007, 06:49 PM
  #8603
i just made up a front diff but have not put it in yet
but i did last year made a spool and did the mistake of putting on the ring on the pulley
Old 06-05-2007, 06:50 PM
  #8604
rmdhawaii's Avatar
Very good. That is part T0258B in step 2 of the MTX-4 manual. As you stated, you're not suppose to use that part when using the front diff. It's easy to overlook that if you're reusing the pulley from the one-way.
Old 06-05-2007, 06:54 PM
  #8605
Ok, well I looked and it does have the ring...
will that fix the issue of it hitting the steering rack when it turns?
kaotickc is offline
Old 06-05-2007, 06:59 PM
  #8606
lil-bump's Avatar
Trader Rating: 89 (100%+)
If your diff rubs and seems too wide. Check and make sure the pulley is fully seated on the diff housing. Take a real close look you will see that the pulley is slightly off the diff housing. I had the same problem.
lil-bump is offline
Old 06-05-2007, 07:10 PM
  #8607
Well, I tried installing the diff with no pulley at all......the steering arms still hit the diff housing.
kaotickc is offline
Old 06-05-2007, 07:17 PM
  #8608
rizal_eg9's Avatar
how many diff gasket are you using????did you put too much sillicone glue or something???or maybe make sure that the bearing goes all the way in on the diff case.....
Old 06-05-2007, 07:22 PM
  #8609
rizal_eg9's Avatar
this is quite interesting.....as i was thinking off bringing down the internal ratio too.....but your set up now have bring the rear internal ratio to 1.95 from 2.15 and with 25 t pulley even with the same tyre diameters....you still have about roughly 10% more rear wheel drive.....
in any case how does it translate to driving feels???
Old 06-05-2007, 07:43 PM
  #8610
gentleman81's Avatar
2nd MTX4
is that shyt fair???
gentleman81 is offline
