Mugen MTX-4
#7846
Originally Posted by wario69
Are there anyone here using Skyline's alum mid block? I'm considering throwing this in my car and wonder if this worth the small investment. I'm also, since I'm at it, I'm also thinking about adding locked front one-ways. Any inputs guys. http://gasrccar.com/eshop/newsdesk_i...eccb1b385b9799
-- Wario
-- Wario
The skyline parts fit is perfect. The spool is always nice to have as a tunning option.
#7847
Originally Posted by Francis M.
instead of all that milling you guys are doing. I suggest lightening the car
as much as possible with ti parts on the drive train & suspension and just use a battery tray with weights such as the one borders rc is selling or there is another one made of brass.
My car right now with some aluminum hop ups is still 1705 grams with the body on which is still 30 grams underweight.
I though this over for a long time and asked many top racers. In the past,
I've done everything to remove weight from the car, and had to add a bunch back in. I had one car that I did, 1634 grams without fuel.
http://www.rctech.net/forum/attachme...hmentid=101421
Since then, I've added lead into the chassis in areas to put the weight down low. Now I have a car that is 1726 with bald tires, right where it needs to be.
I took a light-wieght msr shaft and hollowed it out and also did the same to the 2speed shaft. All the MSR new pully adaptors that just came out, I had to get them, they saved a total of 1.4gms.(LOL,,,what a way to spend $35 for 1.4gms )
Back to seriousness, From every racer I talked to, Lower CG seemed to be more favored than a lighter car, (let me re-fraise: With WIEGHT at 1725g and CG being as low as possible, or just having a car at WIEGHT, Lower CG is prefered)
I don't mind making my own parts, I do it because I don't have anything else to do most of the time, I like to tinker. I get most of the carbon from a buddy, and I cut it on equipment I bought and have in my garage. I do wish to make a run of battery trays in the near future, I'm going to do 50 on the first run, and they will be the best way to get your batteries down low in the car without adding any weight to it. It will lower the CG and alow for some other trick mods if you feel up to doing the work to get your CG down.
#7848
I'm saying to lighten the car with TI screws, Pivot balls, lightened pullies and shafts then use a heavy battery tray to bring the weight back up to legal limit. Just a simpler way of lowering the CG with out compromising the rigity of the car.
Any thing saved on rotating mass pays off big even if it seems like a small difference in the scale.
#7849
I understand that. But using the brass tray in the car, had a few drawbacks. When I used mine, I got a few glitches at first, but then I noticed that it seemed to have lost some grip, like the chassis wasn't flexing as much with the stiffness of the brass, or the option of moving the wieght from front to rear was reduced. A 5gm wieght in the middle of the car does not have the same leverage as a 5gm wieght in the front bumper.
#7850
Your recommendations are sound Francis. I don't think anyone questions that. Like James says, some of us just like to tinker.
I spoke to my friend today and he seems pretty excited about working on this little project. I think the biggest challenge is going to be getting the strength, durability and flexibility of the parts correct.
Just to clarify, my friend has several 3d Printers from Z Corp (http://www.zcorp.com). Once we get the parts into a CAD program (either scanning and/or modeling) all we have to do is mod them and literally print them out. The end result will hopefully be just short of getting the parts from the factory - so in my case, there is no compromise as a result of milling.
#7851
WoW....that machine is amazing! I'm just curiouse how durable the model is and is their matter densities? Hmm...I filled out the information, I have questions!!!
#7852
The titanium machine (made by a different company) is even more amazing. You can mix titanium with whatever other metals you want and it will melt it all together for you. Then just like the Z Corp machines, it just prints it out.
This is really cool stuff James. I just don't know how you're going to explain this to the misses if one of these shows up in your garage one day.
#7853
This is the machine that does titanium parts. It's a bit more expensive.
http://www.arcam.com/applications/index.asp
#7854
I have the 3racing carbon fiber battery tray. Will i see the same results as the brass tray from not being as flexible as the stock tray?
#7855
-- Wario
#7856
http://reprap.org/bin/view/Main/WebHome
Have a look at this concept it's trying to do the same but using materials etc that you can get from your local hardware and electronics store.
Kind of a real neat concept and they have working prototypes.
Sorry I guess this is getting a little off topic
#7857
#7858
When you do get some done let us all know as i think you might need to make a bunch of each to fill our orders out
P.S. R.M.D. Performance Products has a nice ring to it don't you think Rainer?
#7859
Take and put the metal battery tray in the car and then flex it. Then put in the stock one and flex it........just using a chassis. you will see what I mean.
#7860
Originally Posted by Artificial-I
How bout right clicking the link with your mouse and hitting save as.
