V-ONE S Thread
#4351
Re: V1S's shock
Originally posted by Kyosho_GTR
hi guys,
Just wonder is there any shock out there that is recommend for V1S car? And got any pic of the shock? And how much it cost?? What is the diff if install a sturt bar??
hi guys,
Concerning the shocks, see attached picture. This should give you an idea what to buy for your car. Several aftermarket brands offer this type of shocks. It should cost from USD. 30 up to USD. 50 a pair.
If u are referring to anti-roll/ or sway bars, it mimizes the chassis roll of the car. This option is particularly helpful if there are a lot of sharp turns in a race track because it mimizes skidding/sliding while cornering.
#4352
GS15R engine's screw
hey guys,
Just want to tell you all that the screw size for the GS15R is 2mm not 2.5mm. I just brough the screw driver. At first i buy the 2.5 but found out that it don't fix in, so i bring the engine over and try. Its 2mm, so be careful what size u are using so not to round the screw..
#4355
Re: GS15R engine's screw
hey guys,
hey guys,
#4356
Re: Re: My shock
Originally posted by BrainTeased
I used these on my old VoneS they worked well
#4357
Re: Re: GS15R engine's screw
Originally posted by joel
I don't know where you got the info from, but if you check at the v-one s manuals and if you use vernier caliper, THE MEASUREMENT WOULD BE 2.5MM (2.564 MM to be exact) ONLY. Why am i so sure you may ask? Our company branch in Taiwan manufactures and supplies these screws to manufacturing line of Kyosho Co. , Japan.
i don't mean to prove that you are wrong.. But i really went to bought a screws driver for that and i ask for a 2.5mm one, but i reach home and try it out then find it dont fix, and today i went to thhe RC shop and ask them to help me see what is the screw size so to change it..
#4358
Re: Re: Re: GS15R engine's screw
Hi joel,
Hi joel,
Also a inside info for you, 70% of the parts of any branded nitro car kit are not made by the manufacturer themselves. You will be amazed how many manufacturers have subcontractors in Taiwan to do it for them.
#4359
hey pplz
is it possible to run the centax clutch set on the v one s
#4360
2 speed
Does anyone know if there is an after market 2-speed setup for the v-one-s. Mine wears out really fast on the tooth.
Leigh
Leigh
#4361
Re: 2 speed
Leigh
Leigh
#4362
hey i hav 50% optioned my v one s 2 pplz
should i get these options or not
alloy chassis stiffener, graphite top deck, graphite shock towers
#4363
#4364
Does anyone know if wider pitch gears could be used for the vones2?
