Hot Bodies Cyclone
#2971
Hey guys...Just wanted to let you know that the US spec spools (HB Cyclone) are now in stock. The center spool is purple (pic is of prototype spool)
[email protected]
[email protected]
#2973
Originally Posted by John Doucakis
Hara's car from TITC 2006
I think that's a TIR spool with the aluminum cups.]
[/QUOTE]
#2974
most likely he's using the S9451 dig HS servo.
#2977
Originally Posted by EAMotorsports
Anyone notice the Copper shunts on the brushes? Wonder if thats a new compound they are working on?
EA
EA
Yes, good point EAMotorsports.
I think though that these are just the "enduro" (30+ runs) version of the brushes instead of the "sprint" version as it is a bit more durable in high temperature. They were running hot modified motors with high capacity, high voltage GP4300 cells and the temperature was at about 36+ degrees.
That's just a guess thought. I do not have any info on this..
Some more photos..
http://sudacolumn.cocolog-nifty.com/
#2979
what is up with the stuff on the motors, are thoes fancy elecronics or what?
#2980
The copper wire you see is just stripped motor wire wound through the battery bars and zip tied to the motor wire. This also helps keep them in place.
Motor wires unsoldering from V2's is a common problem for the really fast drivers if its hot outside. This only happens to guys that really put the power down and drive hard....I have never had this problem with my V2's
The black shrink wrapped bundle behind Surikarns's motor is a bundle of schottys and caps. This is supposed to keep the motors cooler.
It must have been really hot at the Thai race.
#2981
You have got to love the blue tamiya shock collars lol
#2983
Originally Posted by RaceAce701
How does the front alluminum toe block change the cars performance say from changing from a 2.5 to a 0 degree??
#2984
Why is Surikarn running Nosram ?
#2985
He isn't, he's just using the heatsink. Look closely and you'll see that it's a twister 2.
