Hot Bodies Cyclone
#3001
Maybe it is novak's shottky, but the one on Surikarn's car looks bigger and made by 3 rounds parts????
#3002
I found a part at rc model online:
Brand: Straight
Item: V8 capacitor
What is this for???
Brand: Straight
Item: V8 capacitor
What is this for???
#3003
Its only 8 small capacitors connected together in a PCB so it can perform similar to bigger caps we now use. They also sell this in V4 (4 small capacitors).
#3004
#3005
After running the car this weekend, I have a few setup changes as a used a diff instead of the kit front one-way. I was running Hara's Vegas carpet setup but was losing too much speed in the corners. The car didn't have good off-power to on-power transitions. Changing the ackerman setting alone made the car nearly perfect in the corners. I usually never mess around with ackerman setting but decided to this time. It made a huge difference. The last thing I did was add a little bit more castor to compensate for the abundance of the car's turn-in.
#3006
Greetz florian
#3007
Originally Posted by Hollowman
If you look on surikarns car you see that the black bundle don't connect to anything and for capacitors he has a normal capacitor on his speedcontrol, but where is the black bundle then for ? .
Greetz florian
Greetz florian
I got a Straight V8 looks cool but i wonder if it works just as good. Weird thing is it comes with an extra tiny ceramic capacitor.... i think the main advantage with this unit is it has a flat base you can preety much mount it somewhere in the chassis FLAT
#3009
Originally Posted by lotus1
Am very interested in a Hara or Surkarn edition.Are these available Anywhere yet?Domestic or foreign,doesn't matter.Dealer suggestions?Thanks,Mario.
SURK. MAR onsale
72,000 Yen
#3011
Omg they are sweet as. Wouldnt know which to choose tho if i had the cash to buy one
#3013
HKRC
Do you have stock??
Do you have stock??
#3014
Originally Posted by rc-zombies
the one thing I don't see is the heatsink plate that replaced the CF plate on the motor mount...
