Team Associated TC4
Ahahahah.... Ray I must admit, I have zero practice since the Nyc state championships, but I believe my Car is fast enough to make up for the lack of practice...lol...
Thanks for posting the link ,first I've seen of it !! I'm the Baby blue NSX sitting fourth on the grid !!! Talked to Rick Hohwart, there should be a report on the Halloween Classic in the racing news. On the AE site . Mostly on Hebert's double mod wins in touring and 1/12 scale . Maybe a tidbit on the USGT race !!!
Got the speed down the straight at 3.75FDR, and no motor overheating at all: I can touch it indefinitely... For the corners, I got to give it up to Ray's setup, with the focus on chassis rake... I will be testing further once I get a new body....
I will try 3.4375FDR (55T/40T) next on a slightly bigger track just to see what that does...lol... Fire...ahahah......
Question
What is a good fan & fan mount for the TC4 CLub Spec?
Also is this motor cooling duct junk or does it work?
http://www.rcplanet.com/Associated_M...p/asc31037.htm
Thx...
Thx...
Also is the Reedy Wolfpack the hot lipo for VTA for a TC4?
5000 Mah Wolfpacks come in at 261 grams compared to a normal 5000 Mah coming in at 300 grams.
http://www.amainhobbies.com/product_...5C-74V-5000mAh
I was thinkning it would be easier to add weight to the lipo side side of the car since everything is pretty tight on the right side.
Sorry for the VTA rookie questions....
Thx...
Thx...
Thx...
Thx...
As for as mounting it . Just drill and tap a hole or two along the 45deg. edge of the long "L" section of the motor mount . Use spacers to keep the fan as least 1/2inch between the fan and motor.
I still have to answer your PM ! I'll get to it ! lol
Thx...
Thx...
http://teamassociated.com/pdf/cars_a...d_vta_2013.pdf
Re...setup
works great on my TC4...easy and very reliable
I glad it helped ! If you need more steering ,switch to HPI silver spring in the front . Need more rear grip switch to Tamiya blue spring rear .
Need Advice
I purchased a FT TC4 and got it running, but when I brake it spins out to the right. I changed a front hub bearing that was not free, but the car still spins out. I have changed tires three times.. hpi x patterns, sorex, and some other tires that resemble hpi x patterns. I have also played with the brake settings on the ESC and transmitter, but to no avail. I have checked for binding and did not find any. I am not sure what my next step is... I ran the car on the street for this test (asphalt). Fyi I am running a 5.5 turn motor with a 18 tooth pinion for this test and the spur gear is a 72 tooth. The car is not a missile and should be controllable.... Lastly, the car steers straight and I get it up to a fairly decent speed ...approx. 30 mph... Please advise.
If I get a chance I will take a picture to show the difference.
