Team Corally RDX Touring Car >
Old 03-13-2006, 06:44 PM
  #6331
T1Raycer's Avatar
Smile
thanks a lot dude!!
Later!
T1Raycer is offline
Old 03-13-2006, 06:55 PM
  #6332
Jeff Brown's Avatar
Nice Pictures! I need to steal that one of the X-long for the website to show people how they have to setup the shock end. We put the necessary part numbers on the Specialized website but no one seems to order them. Hopefully that means they have everything.
Jeff
Jeff Brown is offline
Old 03-13-2006, 07:11 PM
  #6333
HarshGuy's Avatar
Jeff
Go for it
HarshGuy is offline
Old 03-13-2006, 09:32 PM
  #6334
Number 11's Avatar
Originally Posted by ebone
what is the hottest mod right now for the rdx?....
The new wood wheels you should try it made by S......p made my car really fast last week.
Number 11 is offline
Old 03-13-2006, 09:40 PM
  #6335
Brian McGreevy's Avatar
You didn't try the concrete ones yet? Those are DIALED.
To answer your question, there isn't really a "hot" mod. There are two categories: 1. stuff that you need, and 2. stuff that you want, and are great to have, but don't absolutely need to be fast.
For carpet, #1 would be (providing you have a carpet spec kit): Lowered front shock tower, black spring set, 6 degree caster blocks for tuning, and low suspension blocks all around.
#2 would be things like the X-tra long rear extensions, motor fan/guard, etc.
#1 for anyone with any kit racing on any surface would be the SRC hard foam bumper/kydex combo, part # SRC1005.
Brian McGreevy is offline
Old 03-13-2006, 10:06 PM
  #6336
syndr0me's Avatar
Trader Rating: 32 (100%+)
Lame lowered shock tower! C'mon Corally, I'll pay you money not to use my damn Dremel! Where's some shortened shock shafts? :-)
syndr0me is offline
Old 03-13-2006, 10:10 PM
  #6337
syndr0me's Avatar
Okay, maybe I should just man up and cut them. What are you guys using, a cut off wheel? 3mm from the piston and 3mm from the ball end and that's it?
syndr0me is offline
Old 03-13-2006, 10:15 PM
  #6338
You got it.
Old 03-13-2006, 11:03 PM
  #6339
Trader Rating: 16 (100%+)
Originally Posted by HarshGuy
Here's extra longs: (pictures deleted)[/img]
Harsh,
Is that car currently legal 190mm width as you have it setup?
Bill
Still Bill is offline
Old 03-14-2006, 04:39 AM
  #6340
HarshGuy's Avatar
Originally Posted by JRX-S Bill
Harsh,
Bill
Yep, ran through the techbox and all, I actually am using HPI hexes as they are narrower than the standard Corally hexes, a little wider than the Corally narrow ones and they have shims in .25 & .5 mm sizes as well, e.g. the front end could actually be a little wider with the hpi hexes so I have the .25 spacers on the front.
HarshGuy is offline
Old 03-14-2006, 05:09 AM
  #6341
Trader Rating: 21 (100%+)
Default Hey
Need a start point.Running on ozite with foams.The local guys said to start with the Cuffs setup.Which one?There's 3 listed on the corally site.Anybody try the Tossolini setups?Comparison? Running stock,handout monster.Thanks.
lotus1 is offline
Old 03-14-2006, 05:27 AM
  #6342
HarshGuy's Avatar
Is this only if you're running the Parma Alpha? ...I don't really like the feel of it as compared to the G6, so I haven't converted my cars over to the lower shock towers ...I have them, just haven't "dont the work" as my understanding was it wouldn't really make a diff handling wise for the car, just let's you slam the body more (which I can't with a G6 and still be ROAR legal), or mount the lower profiled front end shells (like the Parma Alpha).
HarshGuy is offline
Old 03-14-2006, 05:34 AM
  #6343
Glowster21's Avatar
Trader Rating: 136 (100%+)
Daygers Novak setup is a SOLID starting point. Just toy with the springs and shock oils from there. I don't have the SRC X Long rear extensions so I went up on both front and rear springs and dropped to a 50wt oil in the front shocks. Car is VERY free in stock and 19 turn and rotates like you wouldnt believe. Good luck and have fun!!!
Glowster21 is offline
Old 03-14-2006, 05:39 AM
  #6344
IN stock form,you can't use the parma alfa body on this car without the lowered shock towers?That kinda isn't cool.lol.What bodies will fit without the mod.Thanks.
lotus1 is offline
Old 03-14-2006, 06:37 AM
  #6345
CrashTstDummy's Avatar
Post New Sponsors
Ray Darroch has made the move and is now running with JACO and SMC batteries!!....along with his Corally ride.......Congrats Ray!! would be great to see him bring back some hardware from the Nats.
CrashTstDummy is offline
