Spec-R Gear diff review >
Old 09-11-2010, 09:09 AM
  #541
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Use XRAY 7075 T6 Hard coated bester !
RC MARKET is offline
Old 09-11-2010, 11:18 AM
  #542
Default y
+1
on d way is offline
Old 09-11-2010, 12:53 PM
  #543
jonest's Avatar
Has any1 tried metal gear with the 3racing gear? Not to say that the gear is weak but would like to try metal gear somehow...
Thanks for the tip.
jonest is offline
Old 09-11-2010, 03:55 PM
  #544
Satish's Avatar
This is what I was afraid of, now I gotta get new shafts.
Im not sure how changing roll center will fix my problem, I still wont be able to adjust camber, right now I have 1.5 caster.
thanks guys
s
Satish is offline
Old 09-11-2010, 06:31 PM
  #545
Trader Rating: 88 (100%+)
thanks guys
s
the original posted mentioned adding another .75 shim to the rollcenter holders to increase track width and move the driveshafts....
joey is offline
Old 09-12-2010, 11:22 AM
  #546
Originally Posted by sidecarphil1
Or space the lower rear roll centres out buy .075 per side
This is what i did
thanks guys
s
just add 0.75 mm spacers to the 4 roll centre adjusters then it fits
sidecarphil1 is offline
Old 09-13-2010, 03:34 PM
  #547
Hi all;
No news about the Yokomo Gear Diff???????????
JordiM is offline
Old 09-17-2010, 07:33 AM
  #548
I've run my TRF416X for the first time with the geardiff and the car was very different to drive.
Different in the positive way, the car handled so much smoother and was easier to drive.
I sure was much faster with the gear diff then with my ball diff.
And that's what we all want, to go faster with less maintenance
addicted2blue is offline
Old 09-17-2010, 07:38 AM
  #549
M-Technic's Avatar
Trader Rating: 15 (100%+)
I am still loving my Spec R gear diffs. But they need to be rebuilt more often than you think. Not because the internals are wearing out, but because the oil breaks down and leaks out which really softens up the diff over time.
M-Technic is offline
Old 09-17-2010, 08:41 AM
  #550
kschu's Avatar
Trader Rating: 16 (100%+)
have u try changing to Xring?
kschu is offline
Old 09-19-2010, 07:23 AM
  #551
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Does anyone know were to get oil in finer increments (around 20k) of oils ranging from 150,000 to 500,000? Or am i going to have to mix my own?
Thanks,
Antoni
Yokomo_Ant3 is offline
Old 09-19-2010, 10:35 AM
  #552
Changing to the new X O-ring makes no differences from what I can tell. It still leaks. The leaking from the pulleys can be fixed with some automotive sealant. They really should release some rubber gaskets for the diff.
itchynads is offline
Old 09-19-2010, 06:01 PM
  #553
Satish's Avatar
where can I get this in Canada or the US, I dont want to go through china again
s
Satish is offline
Old 09-19-2010, 06:40 PM
  #554
s
if your looking for the xray version, Nexusracing has them in stock..
http://www.nexusracing.com/product_i...oducts_id=3267
joey is offline
Old 09-19-2010, 07:55 PM
  #555
Mike Haynes's Avatar
Does anyone know which spec r gear diff will fit in the tcx? I would think the tamiya one? Thanks
Mike Haynes is offline
