Losi XXX-S
#9751
R/C Tech Elite Member
The plastic gear seems to hold up fine for me. I had a kevlar in there, but it was horribly loud, sounded like a bad gear mesh almost. Josh Numan told me to go with the plastic gear, and the car was instantly quiet. It holds up to my 6 turn D6, so I dont think anyone else will have problems as long as the mesh is correct.
#9752
Originally posted by James Nguyen
plus the spur and adapter are black!
And that matches your black belt...kewl!
So, that covers the sound aspect; but, what about performance? No difference noted?
#9755
Wow! Posts from three out of five of my favorite contributors.
Going to give the quieter plastic gear a try. If nothing else, I can use it to sneak up on my competitors...
#9757
There is no performance difference between the plastic and kevlar, and although I havent weighed them, the plastic actually feels a hair lighter.
There's nothing better then hearing the roar of a mod motor on the straight, cant drain that sound out with a loud gear...
#9758
I've been using the kevlar gear and it has never been loud... the only sound I hear out of my car (unless I'm mistaken) is the sound of the motor and belt whurling up at top speed.
E
E
#9760
Kevlar Gear
I have been using a Kevlar gear that I drilled out on a homemade jig. I use a very light coating of teflon based gear solution that I got from a bike shop. I cannot hear my gears at all, and my car seems to be a little faster since trying this.
#9761
to each his/her own, what works for one may not work for the other... sometimes the more opinions the better
E
E
#9762
Funny you should say that. I've thought about using some of the teflon based gear lube at the mtn. bike shops before. They make dry lubes that are slick as hell and quiet down the geartrain of a mountain bike real quick but they don't attract as much dirt as a liquid based lube would. Anyone ever had negetive results from trying this?
#9763
Gear Lube
I use the lube each time I run the motor, and I only run a motor once so I essetially relube before each run. Over time the dry teflon accumulates on the bottom of the drivetrain tunnel. I take the bottom plate off and clean it about once per month. Otherwise, I have not had any problems.
#9764
any word on those bk bones yet?? and what do you ppl think about the black belt system, i think ill have to go back a few pages since i was out of town and missed like 8 pages of this form.and if anyone know a lhs or a online store withe the blk belt kit in that would be great.
lazy
lazy
#9765
I know Randy made some of his own BK Bones and they seem to work pretty well. I wasn't too impressed with the black belt at first but this week I rebuilt my entire drivetrain. I didn't realize the bearings that I had pulled all the seats out of and worked on were in the other car I sold last month and was wondering why the drivetrain felt a little tight even with the black belt. Worked on the bearings this week and rebuilt the car from the ground up. It's more free than It's ever been. I can really feel the difference the black belt makes now.
