Losi XXX-S
#8536
i was reading threw some r/c mag. and i saw todd hodge's car, if anyone knows but, those extra holes that he dremaled/milled for the for camber postions and size they are or should be and the correct placement so that the car still works with the new holes please let me know cuz ive been having trobles with foam set-up on my car.
LazyBoy
LazyBoy
#8537
I used a 3/32 drill bit on my shock tower. Just drill it up and between the stock holes.
#8539
Diffs
Proudwinner,
Are you saying that just one of the two diffs is loosening up? Or both?
A possibility...Check if the conical washers in the male outdrive are in backwards. They should have their concave side facing inwards. (Oops! You already were told this.)
Tell your friend to consider cleaning and repacking the diffs to be a regular chore. I do both diffs every 5-10 runs depending on cleanliness condition of the track. Use Losi red grease on the little balls in the female outdrive and Losi diff grease on the rest.
#8540
Jitsuguy: sounds like your turnbukles are too long... i used to run the offsett hubs and have no problem with the amount of camber.
#8541
Thanks for the help fellas... What I did for a quick fix was to move the ball end to the outter hole on the hub instead of the inside one. It sucks cause I only like to make one adjustment at a time, but now I made 2... I'll get shorter turnbuckles if this setup doesn't work how I like it to, to really test my car setup with just the new offset hubs.
J
J
#8542
#8543
The Evicerator
So, how's everyone's cars running??
#8544
Great! Geez I'm bored.
#8545
What again does lengthening the turnbuckles do, or shortening them? For handling? Wow, raced monday nite, that belt trick, is the best thing ever, now if my front diff/spool would stay together, and my lhs would get my stupid diff balls in stock i would be in heaven. Also, does using the AE hexs eliminate the rubing while using 28mm.
#8546
XXX-S owners, anyone got a pic of the bellcranks mounted forward and flipped? I just did this and it looks a little akward as I have no pic or diagram to go by. Oh and by this mod it looks like there will be more ackerman, is this correct? I would post a pic of what I got but a friend has my d-camera.
#8548
cant wait to join everyone else in having a xxx-s g+ just trying to find a good deal.
everyone around my hobby shop usually runs tc3's and some hpi, not many with losi. i have been into losi since the beginning.
i borrowed my friends street weapon awhile back and took out the whole field believe it or not, they were like man thats heavy and i was like really, cant wait to see what i can do with a lighter weight for efficient tourning car.
#8550
Thanks for photos
Thanks for sharing the Street Weapon photos. I'm fairly new and was wondering what one looked like. Interesting layout!
