Xray T1
#2417
Re: Just about to buy an EVO 2...which one?
Originally posted by wrxmy99
Hey all
I presume that the C-Hub equipped kit doesn't come with the original pillow ball suspension as well???
Given that the kit with C-Hubs is more expensive why should I look at the C-Hub kit over the original pillow ball??
One of my MAJOR gripes with the Pro 3 was the amount of slop in the C-Hub setup, I was hoping the XRAY pillowball setup would remove that...hence I'm nervous about going to C-Hubs again.
Hey all
but can't buy a conversion kit to change it to pillow ball. as with the pillow ball kit...you can just get the C-hub conversion kit..
I had the Hara Pro3...C-hub is full of slop..you have to shim it to make slop free. On the Xray...the C-hub design is the best I've ever seen. Quality and fit is perfect. virtually slop free!
unlike the Pro3...it has very little flex. and the arms are stiff and designed to take a beating.
#2418
Originally posted by Scrad
Hey guys, I was wondering what the differences are from the T1 to the evo2? Is the T1 still worth getting for under 200? And could you upgrade the parts on the T1 to make it a evo2? Thanks for any info you can give me.
#2419
I ageree The Xray T1 is a steal at that price.. You can easily upgrade to the Evo 2 Parts if you choose but performance wise you would probably see little difference between the two...
BTW where can you get the T1 for that price?? Is there a website??
Steevo
Steevo
#2420
Do NOT buy a T1 if you want an EVO
i looked in to the up grade option and it,s f...in expensive
having said that the T1 is a great car all the same
but if you want a evo buy an evo !!
#2421
How many of you actually use a different battery layout other than that like the evo 1 on your evo 2's???? it seems that is the only major refinement of the evo 2...... , things like a-arms, and hubs just can be replaced as you break them to evo2 stock........ and if you plan on a c-hub swap why worry????? then you can have a brand new c-hub car for the price of the evo2......LOL
#2422
The bulkheads with the adjustable bearing carrier (for belt tension) cost about $95.00.
#2423
Or.....get a belt tensioner for $15.
#2424
hey guys anybody intrested or know anybody looking for a good deal i have an evo 2 five months old carpet car adult owned for $250 and for an extra $120 i will throw in the c-hub coversion front and rear NIB check it out on the rc stuff for sale
#2426
Evo 2 also comes with better bearings.
In all honesty the differences between the T1 and the EVO are not extreme. Most of which are small parts that you will eventually replace anyway. The exceptions would bulkheads with the adjustable bearings, and maybe the dual ackerman servo saver.
The EVO is a T1 with the modifications that increases it's adjustablility more than anything else.
#2427
The original servo saver is no longer available. I had to buy a new saver for my T1. T1 chassis is no longer available either.
#2428
Re: .
#2430
The looser the belts the better off you are. As long as they don't slip, looser belts have less drag on the drivetrain.
