Old 02-02-2003, 10:20 PM   #2416
Scrad's Avatar
Trader Rating: 15 (100%+)
Hey guys, I was wondering what the differences are from the T1 to the evo2? Is the T1 still worth getting for under 200? And could you upgrade the parts on the T1 to make it a evo2? Thanks for any info you can give me.
Scrad is offline   Reply With Quote
Old 02-02-2003, 11:20 PM   #2417
rc-zombies's Avatar
Default Re: Just about to buy an EVO 2...which one?
Originally posted by wrxmy99
Hey all
I presume that the C-Hub equipped kit doesn't come with the original pillow ball suspension as well???
Given that the kit with C-Hubs is more expensive why should I look at the C-Hub kit over the original pillow ball??
One of my MAJOR gripes with the Pro 3 was the amount of slop in the C-Hub setup, I was hoping the XRAY pillowball setup would remove that...hence I'm nervous about going to C-Hubs again.
yes..the C-hub kit doesn't come with the pillow ball suspension.
but can't buy a conversion kit to change it to pillow ball. as with the pillow ball kit...you can just get the C-hub conversion kit..
I had the Hara Pro3...C-hub is full of slop..you have to shim it to make slop free. On the Xray...the C-hub design is the best I've ever seen. Quality and fit is perfect. virtually slop free!
unlike the Pro3...it has very little flex. and the arms are stiff and designed to take a beating.
Old 02-02-2003, 11:54 PM   #2418
David Galdo's Avatar
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
The T1 is a steal at $200 or below, and 99% of what the Evo2 has can fit the T1.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 02-03-2003, 12:05 AM   #2419
Steevo's Avatar
I ageree The Xray T1 is a steal at that price.. You can easily upgrade to the Evo 2 Parts if you choose but performance wise you would probably see little difference between the two...
BTW where can you get the T1 for that price?? Is there a website??
Steevo
Steevo is offline   Reply With Quote
Old 02-03-2003, 04:08 AM   #2420
Merciless's Avatar
Send a message via ICQ to Merciless
Default Do NOT buy a T1 if you want an EVO
i looked in to the up grade option and it,s f...in expensive
having said that the T1 is a great car all the same
but if you want a evo buy an evo !!
Merciless is offline   Reply With Quote
Old 02-03-2003, 07:35 AM   #2421
How many of you actually use a different battery layout other than that like the evo 1 on your evo 2's???? it seems that is the only major refinement of the evo 2...... , things like a-arms, and hubs just can be replaced as you break them to evo2 stock........ and if you plan on a c-hub swap why worry????? then you can have a brand new c-hub car for the price of the evo2......LOL
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 02-03-2003, 07:54 AM   #2422
The bulkheads with the adjustable bearing carrier (for belt tension) cost about $95.00.
Nanook is offline   Reply With Quote
Old 02-03-2003, 08:00 AM   #2423
Default .
Or.....get a belt tensioner for $15.
elnitro is offline   Reply With Quote
Old 02-03-2003, 08:08 AM   #2424
mike5009's Avatar
Send a message via AIM to mike5009
hey guys anybody intrested or know anybody looking for a good deal i have an evo 2 five months old carpet car adult owned for $250 and for an extra $120 i will throw in the c-hub coversion front and rear NIB check it out on the rc stuff for sale
mike5009 is offline   Reply With Quote
Old 02-03-2003, 08:34 AM   #2425
Scrad's Avatar
I was just wondering about the T1, because I read that the evo2 has some other improvements over the T1. I'd rather have the evo2, but I was thinking if I break stuff I could buy the evo2 parts to fit the T1. Otherwise I might just buy Mikes car.
Old 02-03-2003, 09:22 AM   #2426
Evo 2 also comes with better bearings.
In all honesty the differences between the T1 and the EVO are not extreme. Most of which are small parts that you will eventually replace anyway. The exceptions would bulkheads with the adjustable bearings, and maybe the dual ackerman servo saver.
The EVO is a T1 with the modifications that increases it's adjustablility more than anything else.
Old 02-03-2003, 09:34 AM   #2427
RC Nitro's Avatar
The original servo saver is no longer available. I had to buy a new saver for my T1. T1 chassis is no longer available either.
RC Nitro is offline   Reply With Quote
Old 02-03-2003, 10:15 AM   #2428
dtm
dtm's Avatar
Send a message via ICQ to dtm
Default Re: .
Or even make your own with a servo horn for the price of a couple of bearings! Adjustable bulkhead are "nice to have" definately not a real upgrade.....if you already have a T1.
dtm is offline   Reply With Quote
Old 02-03-2003, 01:05 PM   #2429
Espcially concidering yu have to tear the car apart to adjust the belt tension..... I prefer belt tensioners myself......
Old 02-03-2003, 01:07 PM   #2430
The looser the belts the better off you are. As long as they don't slip, looser belts have less drag on the drivetrain.
