New Team CRC Gen-XL
#211
From the CRC Gen-X Tuning Guide:
"...Adding rear droop (up to about 3mm max) can give the car more rear grip and a more consistent feel on bumpy tracks. On smooth tracks, the car will not use this extra travel and you will notice very little difference, if any."
Anyone disagree with this statement? Not all tracks are consistently bumpy or consistently smooth, so might it make sense to always run up to 3mm of droop?
#212
I use Losi silicone diff fluid myself, but whatever is available to you will work. I like to tube the Losi comes in. There really is not a need to change the side springs, but if you decide to do that, I would not change the tube lube at the same time. Change one thing, and then if you decide you need more dampening, then change the tube lube. Depending on the bite you are running on, you might need to drop to 30,000 or even 10,000.
dumper
dumper
#214
dumper
dumper
#215
What is the popular body with this car? The track surface looks to be about 100 x 50. I plan on running 17.5 or 13.5 lipo depending on what turnout is. Which servos do not require any redrill of the chassis?
#216
CDW- Thanks for all the information.
#219
Problem
I have a somewhat frustrating problem with my car that I could use some help with.
The short version is that the pod does not sit level with the chassis.
The longer version is this: pod was built off of the cars. It sits level and flat on the setup board with absolutely no tweek. Chassis is built up the same. It sits perfectly level and flat on it's own. Connected together without the shock attached everything sits level and flat. Connect the shock and the right side of the pod sits 0.5mm higher than the left. This is seen when sitting on the board or sitting on 10mm blocks or sitting with the wheels on the car. A few other notes: side springs are backed all the way off and are not touching the pod, damper tubes are off the car, rear bulkheads are not bent, lower pod plate is new, screws on the side links have been backed off and the links will actually fall under their own weight.
Any thoughts?
Any thoughts?
#221
Any thoughts?
Any thoughts?
#222
#223
Any thoughts?
Any thoughts?
