New Team CRC Gen-XL
#61
http://www.teamcrc.com/crc/modules.p...showpage&pid=7
There are no new setups for the Gen-XL yet but I'm sure there will be soon. I think about the only thing they did different was go down a step on the center spring because of the lighter lipo packs.
Keep an eye on the website cause I'm sure Vegas setups will be going on there pretty soon.
#63
There are some setups in the tech section of the website, located here
#64
For those looking for the conversion kit, we have a few left over from the IIC that Frank was kind enough to provide us with. For those who followed the race, I think you'll agree that the car was very successful! Here it is: http://www.ampdraw.com/product/13133...Conversion-Set
Horizon shows that they will be in stock tomorrow -- not sure how accurate that is -- but I'd expect them to begin showing up elsewhere very soon.
#66
#67
-Left Side Micro Bulkhead=PN 3351
Caster Blocks=The kit comes with 0,5,10 degrees.
-Aluminum part numbers:
0 degrees=PN 3360
5 degrees=PN 3361
10 degrees=PN 3362
-Standoffs=PN 1260
-Hardware (screw kit)=PN 1410
Hope this Helps,
CD
#70
Yes, if I were you I would also look into getting the Gen X Graphite cross brace. The part number is 3277.
Also, if you are getting the Cross brace I would also check into getting the new arms, that way you can have the option of running short and long arm. The part number is 3348.
Hope this helps,
CD Wells
#73
Trader Rating: 50 (100%+)
Looking forward on running the new car, although I had a few questions pertaining to recommended size of spurs needed for 13.5 and Mod????
Further if there is a range of recommened pinions needed, as mentioned per the above question.
Any feedback would be great ......................... Thank you again in advance!!!!
Alex
Alex
#75
Anyone know if the molded plastic left side open pod (included with the XL kit) is available as a spare part?
