Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 04-19-2011, 07:12 PM
  #4966
The Big Wig's Avatar
Teflon tape on the pads wich are then sanded down (not done in the pic yet) allong with the friction plate.
Aero tape on wing underside. This is the same stuff that iceskaters put on their legs to create little vortexes and fill the underpressure behind their legs (if it helps on that car I dunno but I'll annoy some fellow racers for sure).
6x0.7mm beveled piston holes (harder rebound).
Attached Thumbnails Tamiya F104 Pro!-img_2846k.jpg   Tamiya F104 Pro!-img_2845k.jpg   Tamiya F104 Pro!-img_2853k.jpg
The Big Wig is offline
Old 04-19-2011, 07:19 PM
  #4967
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I too can appreciate all the attention in the details.
For many of us the build is as much fun as it is to drive, perhaps more-so...
Some folks try to build a better mousetrap.
Some build the same trap, with no exception to detail.
It's all good.
RedBullFiXX is offline
Old 04-19-2011, 07:32 PM
  #4968
A problem with the chewing of the setscrew in your carbon axle is something we've all seen before. This is my F103 axle that has 2 seasons under it's belt.
First ground your setscrew perfectly flat and CA a 0.1mm steel plate on the shaft. Make sure the plate fits just right becouse if it's to small it can twist and it will be impossible to take it apart again.
Attached Thumbnails Tamiya F104 Pro!-p1060433k.jpg   Tamiya F104 Pro!-p1060434k.jpg   Tamiya F104 Pro!-p1060436k.jpg
Old 04-19-2011, 07:50 PM
  #4969
A nice option is the Tamiya Clamping hub.
It also comes in black.
I find that the thicker ribs offer more contact area for the wheel, keeping it more in tact after a big hit.
Set screw is optional, and not really necessary.
http://www.tamiyausa.com/product/ite...oduct-id=84196
http://www.tamiyausa.com/product/ite...oduct-id=54240
Old 04-19-2011, 08:01 PM
  #4970
Shure but U still have the diff side
Old 04-19-2011, 08:08 PM
  #4971
squarehead's Avatar
Trader Rating: 75 (100%+)
Originally Posted by The Big Wig
I even changed the servo bearings to ceramics.
Polished the chassis (see the reflection of the drapes).
Sanded down the screws.
You don't have a girlfriend, do you?
squarehead is offline
Old 04-19-2011, 08:34 PM
  #4972
Trader Rating: 19 (100%+)
Originally Posted by mattwoodcraft
i would have to agree that the pics of the F1 on the previous page are very impressive
i twill be interesting when i start racing again it must be at least 3 years ago i decided to stop and have a break from electic racing
Good call on the black can. One thing i'll say is gear down to a really low ratio. Run something like a 65 spur and 20 pinion. The black can probably wont like it too much, but yeah it'll make it easier to drive.
Parts wise not a lot. I had never broken anything till the state titles. The car is tough as nails. I broke a carbon drive shaft at the states on practise day, not sure how, must be one too many barrel rolls :P Some spare spurs are about all you'll need. In any case... i have all the parts you could ever need for your car at the track so if you ever need something, my pit box is always open
LordAnubis is offline
Old 04-19-2011, 08:58 PM
  #4973
Fancy the same car?
I'll give you a headstart with the partslist:
F104 M.A.D. Spl.:
Tamiya: (http://www.tamiya.com/)
42131 HL Cylinder For TRF Special Dampers (2pcs.)
42137 Competition O-rings for Oil Damper
42165 TRF Damper Pistons (Blank / 4pcs.)
50395 Racing Developed Front Upright Set (1 Pair)
50509 F-1 Front Spring Set
53101 Racing Developed 0.4 Steel Pinion Gear Set (20T, 21T)
53102 Racing Developed 0.4 Steel Pinion Gear Set (22T, 23T)
53103 Racing Developed 0.4 Steel Pinion Gear Set (24T, 25T)
53117 Racing Developed 0.4 Steel Pinion Gear Set (26T, 27T)
53120 Racing Developed F-1 Aluminium Front Body Mount
53259 Formula 3.5mm Offset Upright
53262 0.4 Steel Pinion Gears (28T, 29T)
53918 Low Friction TRF Damper V-Parts
54160 F104 Titanium Coated King Pin (2pcs.)
54161 F104 Low Friction Suspension Ball Set
54165 F104 Soft T-Bar
54166 F104 Aluminium Motor Mount (Left & Right)
54202 F104 Aluminium Upper Suspention Mount
54208 5x8mm Aluminium Hex Head Ball Connctor (Fluorine Coated, 5pcs.)
54209 5x5mm Aluminium Hex Head Ball Connctor (Fluorine Coated, 5pcs.)
54222 High Traction T-Bar
54278 F104 Separated Upper Deck
54281 F104 Heavyweight Pivot Post
84013 5mm Aluminium Short Ball Nut Black (10pcs.)
84120 RC Body Set Ferrari F60 – Lightweight
84170 F104 Pro Black Special with Light Weight Body
3455898 Antenna Post
14005133 F104 Lower Deck
14025071 F104 Upper Deck
Abec 35: (http://www.abec35.com/)
3.0mm C 3.0mm Ceramic Diff Balls (10pcs)
MR106(2.5)-C3 6x10x2.5mm General Ceramic Hybrid Ball Bearings, ABEC3(x2)
MR115-XCO 5x11x4mm Type X Ceramic Hybrid Ball Bearings, XCO
Associated: (http://www.teamassociated.com)
#8546 M2x6 BHCS Blue Aluminium (4)
#8547 M2x6 FHCS Blue Aluminium (4)
Atomic: (http://www.rcatomic.com/)
TS-BSM2612M M2.6x12 Titanium Button Head Hex Socket – Machine (10Pcs)
Blade: (http://www.blade-racing.com/)
BL616 Friction Pad
Boca Bearings: (www.bocabearings.com)
#SW85C-OS7AF2 5x8x2.5mm Orange Seal Ceramic Bearing (4 pack)
#SW106C-OS7AF2 6x10x3mm Orange Seal Ceramic Bearing (4 pack)
#SW128C-OS7AF2 8x12x3.5mm Orange Seal Ceramic Bearing (4 pack)
HPI: (http://hpiracing.com/)
102832 Helmet Parts Set
Kawada: (http://www.kawadamodel.co.jp/)
B61M Thin-Shaped Heat Sink M
FO27 Delrin Suspension Ball For F103
Keyence: (http://hobby.keyence.co.jp)
OP-84432 Chevalier Dash
Ko Propo: (http://www.kopropo.com)
21002 KR-409S Micro Reciever
30048 PDS-951 ICS Servo
40047 VFS-1 Pro C3
45515 Ultimate Shotki Diode Single
Kose: (http://kose-rc.com/)
K-1604 3mm Shim Set
K-1633 1050 to 850 Bearing Holder
K-1636 6mm Shim Set
MRT: (www.team-mrt.com)
PTX Transponder
RC Square: (http://rc-square.com/)
SFC-20G Tamiya F103 Height Adjustable Guides
SGE-14SBK Aluminium 4mm Flanged Serrated Nut
SGE-905BK 0.5mm Spacer Black (8Pcs)
SGE-910BK 1.0mm Spacer Black (8Pcs)
SGE-915BK 1.5mm Spacer Black (8Pcs)
SGE-920BK 2.0mm Spacer Black (8Pcs)
SGE-925BK 2.5mm Spacer Black (8Pcs)
SGE-930BK 3.0mm Spacer Black (8Pcs)
STR-335 3x35mm Hex Countersunk Screw
STR-430 4x30mm Hex Countersunk Screw
FAW-306B 3x6 Hex Flanged Buttonhead Screw (4 Pcs)
Squat: (http://www.squat.co.jp/)
S786 Tamiya F103 Roll limiter
Take Off: (http://takeoff.main.jp/)
TO-365BK High Traction Tape
TS-252 Titanium M3 Locknut Thin Type (H3.3)
TS-208BK M4 Locknut Thin Type
TS-205BK M2 Locknut Aluminium
TS-201BK M3 Locknut Aluminium (H4)
TS-207BK M3 Nut
TS-332BK M3x8mm Hex Socket CSK Screw
TS-333BK M3x10mm Hex Socket CSK Screw
TS-381BK M3x6mm Hex Socket Button Head Screw
TS-382BK M3x8mm Hex Socket Button Head Screw
TS-383BK M3x10mm Hex Socket Button Head Screw
TS-384BK M3x12mm Hex Socket Button Head Screw
TS-111BK M3 Washer Aluminium 0.5mm
TS-1151 M3x6mm Magnesium Button Head Screw
TS-1152 M3x8mm Magnesium Button Head Screw
TS-1153 M3x10mm Magnesium Button Head Screw
Team Orion: (www.team-orion.com)
ORI14155 TS Rocket Pack LiPo 3500 IBS
Titanium Racing: (http://www.titaniumracing.com)
6 mm M3 Titanium Countersunk Screw
8 mm M3 Titanium Countersunk Screw
10 mm M3 Titanium Countersunk Screw
12 mm M3 Titanium Countersunk Screw
20mm M3 Titanium Countersunk Screw
TOP Racing: (http://www.top-racing.jp)
TI-CM0206 Titanium Coutersunk Machine Screws M2x6mm(10Pcs)
TQ Racing: (http://www.tqracing.com/)
#2200 Triple Black 22 Gauge Servo Extention
#13313 13 Gauge Wire Black
TRG: (http://www.rc-trg.com/)
TRG-5029 Rear Ride Height Blocks
TRG-5088 Servo Saver Horn Short
Old 04-20-2011, 04:32 AM
  #4974
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
I've broken 2 clamping hubs in 2 races, not sure if the 2 I bought were bad but I snapped both in half within 2 runs.
abailey21 is offline
Old 04-20-2011, 05:17 AM
  #4975
mattwoodcraft's Avatar
thanks for the heads i hope to be down very soon
what packs you running in your f1 this is all that i need to get now or what are you other guys using ?
mattwoodcraft is offline
Old 04-20-2011, 06:50 AM
  #4976
Wow !
Got any pics
I'd like to see that.
Admittedly, I don't run F1 much these days, but I've had good luck with them on the 104 I had, and on my 103AE.
Old 04-20-2011, 11:56 AM
  #4977
HeliYogi's Avatar
Trader Rating: 17 (100%+)
Default Thanks Barry!
Fancy the same car?...
Bro I got your post copy pasted on the F1 data file
Thanks!
Marcos
HeliYogi is offline
Old 04-20-2011, 01:00 PM
  #4978
Thanks!
Marcos
I allready regret this. Took my months of research.
But hey developement never stops and I've allready some new ideas!
Old 04-20-2011, 01:42 PM
  #4979
New updated setting sheet.
Old 04-20-2011, 02:41 PM
  #4980
HeliYogi's Avatar
Yes, written in true McLaren spirit!
My .02 (it works for me ) since we are sharing our nicest garments
When starting to run a F103, 104 or most T plate, 2wd 1/10 chassis:
1. If the steering is of (and the front is as it should) then... Check the T Plate (adjust your TX exp, this cars do well with less than 80% steering)
2. Bad cornering, even with those expensive nice soft rear Rides or Pit's rubbers or foams... Check the T Plate (then the diff)
A) Tight Diff is easier than a loose one (usually you adjust it from less to more traction). Try to find the Diff G spot (the “Good spot” you Prev!) get it worm first - do 5 or 6 laps. A cold Diff? No can do! (This sort of reminds me of something... oh yea.)
3. Difficult to hold it straight? Even worst when you power it full... Check the T Plate.
4. T Plate like's it loose, easily swings from left to right - just like dancing Slasa or Merenge! Do swing test with your body on (the car not yours Jees!). Too loose? You lose! Compensate by adding tension on the plate - but just a tad, remember loose left, right, left, right... Mambo!
5. Beginner? Try front: .5 toe out / 3 camber . Ride higth between 4 - 5mm level (front, middle and rear), for carpet track as low as you can get away with. When in doubt it's better to be a little lower on the rear. If the rear is higher prepare to salsa (on the wall!)
The rest you will find out as you become an advance racer like Mr. Wig
Go ahead by the parts, do the set up and prepare to be hooked forever
Cheers!
Marcos
HeliYogi is offline
