T.O.P. Racing "Photon" 1/10 EP Touring Car
#8146
In stock at topracing.net.au
Heres the link
http://www.topracing.net.au/shop/ind...&productId=819
#8148
As you would have seen today we have not got our exotec chassis car going as well as our car with the very worn out standard lipo chassis.
#8149
It was spot on today thats for sure.
Just really lost now with what to do
#8151
R/C Tech Elite Member
smaller holes allow for thinner oil
Smaller holes create more "pack"
I'd recommend really sticking with a common set of oil/piston that others have posted. Unless your running mod I'd recommend 42.5 losi and 1.2mm 3 hole. If your running mod you need whatever EJ has in his car!
#8152
Big holes require heavier oil
#8153
Given the same oil, smaller holes will make the car more responsive, especially off center. What do you want the car to do? In lower grip situations I like the bigger holes, I have been preferring either thicker oil or smaller holes when traction comes up, and its not necessarily faster on the lap counter, but it feels better.
#8154
#8155
car just seems to be lacking in traction all around...not pushing or loose feels like more of a 4 wheel drift. if i feather the throttle through the corner it seems like it takes a long time for the car to come to me. it seems to be even worse if i try to power from apex to exit.... i am not always the smoothest driver so i need something that is easy to drive as i do not do well with a twitchy car.
What your describing is not all setup.
#8156
Once I changed set ups to the one Hanulec posted, that made it drive even better.
#8157
#8158
What tires are you using, spec or your choice (#1 setup change, if you don't have the right tires it doesn't matter what you do to your car)? Are you using tire sauce, what kind? What type of surface are you racing on? What body are you using? Can you post your setup?
frt springs are 306
rear are 289
2.0 neg camber frt and rear
1.0 toe out on frt
2.5 toe in on rear
1.2 3hole shock pistons with 42.5 losi oil
frt spool
stock rear diff set a little loose
the sweeps seemed a little better than the solaris mediums...i did try a set of solaris hard compound that seemed to be the best of the bunch. unable at this time to provide more setup info until tomorow.typically i clean the tires with simple green then after they are dry i put on a liberal coat of paragon ground effects
the body is a pf mazda 6
#8159
asphalt track with grape juice and grape soda spray. spec tires are solaris med. or sweep 36.
frt springs are 306
rear are 289
1.0 toe out on frt
2.5 toe in on rear
frt spool
frt springs are 306
rear are 289
1.0 toe out on frt
2.5 toe in on rear
frt spool
#8160
bpalmer,
We run on the same surface, somewhat smooth parking lot with sugar water and pop.
I think your setup may be a bit to soft, try the attached setup.
The car may be a little loose if you over drive the corner but learning to drive with lots of brakes into high speed corners I've found to be essential on low grip asphalt.
This is roughly the same setup i run on carpet, I just put the wing screws back in, run a stiffer front spring 367 or 393, and ~1.5deg frnt \ 2 deg rear camber.
Give this a shot and see if it works. Solaris is a great tire but after the 2 runs they drop off quit a bit on low bite asphalt. Using the paragon my help, we don't run any traction compound at our track so I'm not sure of the effect.
The other thing I've found to be odd at our track, softer tires work better. Track temps run ~130deg around 2nd qual into the mains. Harder tires seem to scallop were softer look great after every run. I'm currently using Muchmore 28's. I'm sure some of this can be fixed with setup but when you can't go out and practice for a whole day to find a setup it's hard.
