Serpent 710
Re: Re: Question
Originally posted by crashed_1
I've stripped 2 sets of 16/61 spur/pinion combo in 3 tanks...i never got it to work too but hell that combo will launch the car to the stars...pity it fails.
How did I get mine to work? I drive on cruise mode?
I notice that with your current meshing on your car, I personally found it too loose for my liking ! I would mesh it further in but that's me...
Originally posted by rcpanama
An on-board, self contained digital battery voltage monitor. Moving your servos show loaded battery voltage. The actual voltage, not a simulated load. You are able to see battery's voltage to the nearest 10mV in easy to read digits.
Anyway, why do you want to monitor the voltage? Your HRS 3PK would go into failsafe mode and lock the throttle servo once your receiver pack goes down to 4.8V.
Re: Re: Re: Question
Originally posted by InitialD
Didn't you mention that it was because of the engine mount to the crankscase was loose?
Thanks !
710 sold... =)
I will still keep in touch though,
I want to thank you guys because in this thread I have learned very much. I want to thank you for you patience when I asked silly and repetitive questions.
Cool gadget but for me, there is too much cluttering on the car. Since you do not have rules, run the car as light as you can ! [/QUOTE
[/B][/QUOTEAnyway, why do you want to monitor the voltage? Your HRS 3PK would go into failsafe mode and lock the throttle servo once your receiver pack goes down to 4.8V. [/B]
The weight without Fuel and Body is 1692g
The monitor will allow me to check if the Servos are doing too much strength so I can fix it or adjust it, this voltage meter weights very little. I am using an 850 GP batteries, I try to avoid getting to 4.8V must of the time.
Must of the Mugen cars weights more than 1700 without body and fuel so I am very light compare to them, but I am learning, only a year since I started raising with my Impulse Pro and now only one month since I started with the 710
I learn a loot from this forum.
what do you have now, profoxcg
710 sold... =)
can I say "MUGEN MTX-3"..............................
Originally posted by Marcos.S710
wow how did i miss that ! i guess it gives better throttle control
I have been moved from one support site to another. What a difference, here it is busy as heck, but it is a pleasure to do support again, not that junk I was doing there... 'Firefighting' if you know what I mean.
Originally posted by BaxterC
Well, I actually put in a longer piece of fuel tubing on the brake linkage and then I put the small piece in with the spring onto the throttle, so that you have more travel on the servo for the brake, gives a more gradual and more precise brake response. (in Theory and testing it it seems to do so) I am running my car for the first time this weekend, not at the track yet, I have not paid my membership fees so I will be looked at funny if I just went, I need to runn everything in, and get everything setup, IE the clutch, the steering and all that, get the car to how I like it, at least into the ballpark, then dial it in from there at the track.
But pay attention on the brake EPA(travel) should not exceed the throttle EPA, otherwise you strain the servo very hard.
I loose one already
Re: Re: I can smile again!
Originally posted by cox049
Mark, I'm sorry about your engine pal... races are races
Why don't you use that extra engine in your 710 instead of insisting with the 705
Well, Mr Pimp man... If everyone liked or wanted a 710, who would be left to run the Mugens... We would have no competition... Or bashing in our forums if everyone wanted a 710?
A lower rear roll center due to the smaller spacer makes the rear end stick better.
That is why I believe Julius found out that the ideal rear oll center and camber change comes from the 4 mm spacer.
6 hours? What a nice life !
Re: Re: Re: I can smile again!
Originally posted by markp27
I checked in the 710 setup book and that's what was recommended - work a treat!!!
Do you mean I should go 1mm lower, or is 4mm the minimum that can be used?
It's hell I have to go again today.....and tomorrow....and.....
I have two JPs on their way one for the 1/8th killer project and now one for the 710
