Serpent 710
Re: setting the front anti roll bar
Originally posted by Profoxcg
Do you guys take your bumpers off?
also see the attached image and please post what the piece i circled is used for and how to use it.
The item you've circled is the droop cam - it is used to get the left and right droop to be the same when the anti-roll bar is attached. Check out Julius' explination of the droop setting in the FAQ - he tells you how to use it
Cheers, Mark.
thanks !
can you attach a pic if what u've cut?
thanks !
thanks !
om ur way to bed??!! its only 4:20 pm here. I noticed most of you guys are not in the USA right?
Here's the pic I promised.
Cheers, Mark.
Originally posted by markp27
Yep, it's now 10:45 pm here - D is probably just getting up now - really international here
Cheers, Mark.
Cheers, Mark.
Cheers, Mark.
Cheers, Mark.
Ooops .. attachement missing!
Re: Re: Re: Re: Re: Deans Charging Plug
Originally posted by B4
I've already ordered the on/off switch they are available from rc-mushroom for $25 USD.
Ahhh now i know who bought the last one !!!!!!!!!! Now I have to wait till they get more.
Re: Re: Re: Re: Re: Re: Deans Charging Plug
Most of what I want was in stock before the weekend
Originally posted by SupermaxxRich
SHOOT!!!! I'm gone a couple of days and I'm behind like 15 PAGES!!!
Re: Re: Re: Re: Re: Re: Re: Deans Charging Plug
Originally posted by KevinS
And which one of ya bought all off rc-mushrooms Hudy tools?
Wasn't me I did that a couple of months ago .
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Thrustbearing after run.
Originally posted by Pyramid
If it is... with your current contribution post on all serpent related forums.. you will save tons of marketing budget.. Not such a bad idea for having Serpent MalaysiaSport D..
Rear Differential (Teddy Syach ideas)
I saw this posted sometime back about putting a Ball Bearing in the rear diff pulley.
This can be found at: http://www.daltonshop.com/tips_tricks.htm
I would like to hear feedback about this modification, good or bad?
I did not find this in Marks FAQ!!!
why dont you get an on/off switch with charging lead option instead? this way you will have only 1 step to charge your battery which is just plug that charger lead in
