Serpent 710
#7906
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: engine shims
#7907
Re: Re: Re: serpent battery
Originally posted by markp27
~snip~ I have GP3300 battery packs - when I discharge them with an NiMH discharger, I can squeeze 4 Amps into them, when I don't discharge them and then recharge, then I only get 2.9 Amps - also the overall power output is lower and the car isn't so responsive.~snipS
When charging, the reading your charger gives is just a mathematical equation of the charge rate multiplied by the time the battery was charged for. When you discharge the battery on a decent charger discharger it will record the correct figure.
#7908
Originally posted by MrChan
Dont have any place for me to click !!!! ...you check first !
just for a hint...they're the 1st runner-up (Sam Chong),5th position (Gary Soh) in A main Asean Race in Kuching, B main Champion (Mahathir) and Labuan Serpent drivers Chris Han.
#7909
Well in my break in proses I have just gone through 2-3 tanks idle at 2 mins cycles because it was too tight and I have now gone through 5 -6 tanks of InitialD WOT style, do I need more or can start to run and lean?
#7910
Re: Re: Re: Re: serpent battery
Originally posted by sparksy
Input Amps isnt an indication of power output of the battery. Only the mah you get on discharge is a reliable indication of the battery's condition.
Cheers, Mark.
#7911
Originally posted by jfc_tech
their faces u can check in my website, under top drivers.
I guess their driving is "cute" too!
#7912
Originally posted by InitialD
Woow ! If I did not see your nick, I would have thought Barry Baker or Josh Cyrul answering that ! Spoke like someone who know his stuff.
#7913
Just like we all sometimes get CONFUSE between you and Julius/Rene/Michael!?
#7914
#7915
Josh Cyrul's servo of choice
Originally posted by Josh Cyrul
PSI - I use the new KO servos - 2344 - lots of torque and plenty fast enough for gas racing!!
Here is Josh Cyrul's response to the servo question.
#7916
Digital Servos
Originally posted by AMGRacer
Read here about digital servos:
http://www.rczone.net/modules.php?n...int&sid=308
#7917
So,should I be getting a battery discharger for my 800 packs I just got for my 710??
#7918
#7919
I have a CDC charger that has an onboard discharger. It is a perfect charger for gas use. Does enough for the reciever, glow, transmitter and starterbox batteries to keep them healthy and happy.
#7920
If your budget extends far enough it wouldnt hurt to have one.
