Serpent 710
#6406
Re: Sorry to be sexist!!!!!!!
Originally posted by Diesel Racer
I see there is a female on the mugen forum who thought the 710 was hard to build compared to a mugen, go figure!!!!!!!
I just know I'm going to get my head bit off for this one.
#6407
Originally posted by cyba888
the rear
the rear
Did the rear body pins come out of the aileron? In my proform mazda6 they did and I had them cut out for the stratus... so I ordered new body posts
The mazda six body is 25mm (1") shorter overall than the stratus. Is this good or bad to handling?
#6408
Nice bright mazda6 cyba888!!
cox049,
The way they mold the wing mounts on the Mazda6 make the 710 rear body post come through the wing. You will need longer body post for mounting the mazda6 on to a 710....... As for handling, this body should be a good steering body........... plenty of front-end downforce for being a shorter body.
cox049,
#6409
Originally posted by cox049
Nice cyba!!
Nice cyba!!
- Stratus 2.1 best handling low to mid speed (aggresive steering)
- Alfa Romeo 2.1 bit under overall especially high speed sweeper. But make the rear of car feels more planted (stable). Very good to cover "unfinish" rear setup
- Mazda 6 sits right between those two !
I guess because having Romeo style in front(bumper) and rear(wing) and stratus 2 in middle section. (angle between engine hood and windshield).
Just my 2 cents
#6410
SWEET! Thanks for the battery link cox049!
I think I'll order up a couple sets of batteries.
#6411
Thanks guys.
Im getting a second kit today at the lhs so I will install the longer body post. It does go throuh the ailerons on the front towards the tip of it. I had to swap the body post to the front side of the rear shock towers to make it fit better. I just hope the aileron piece holds up due to it being kind of thin and the shape of it compared to the rest of the body. Ill let you guys know how it handles when I get a chance to run it.
#6412
As for alternative in your batt pack purchase, ask your supplier, did they carry TOP Racing Product. They has clear shrink too and very strong TIG welding. Not too cheap but very reasonable for green sanyo(730mAh).
#6413
Originally posted by B
In that case, why not buy the SHARK pipe? They are very strong.
The reason I am saying this is that I personally do not find novarossi pipes very strong. They sure are fast, but dents relatively easily. At least this was the case for the previous pipes. Not so sure about the ones now
I tough the public known fix for strengh is not an issue anymore for novarossi..
#6414
Originally posted by Pyramid
SHARK only feels powerfull on short track.. good on the bottom but looks nothing like novarossi on top end. Funny think, they do not even perfect fit for the Tmagic G4 as its manifold is below chassis. I believe it is also the case in Mugen or Serpent cars.
#6415
In that case, the shark pipe would be perfect for lasndown, as the track is still relatively small compared to others. That is, if the pipe can fit properly. If it can, then i think it would be a good choice.
Just a thought
#6416
what do you guys use to attach your recievers to the mounting plate with? Tape? Zap Straps?
#6417
#6418
Originally posted by clmbia45
Thanks. I'v been using 0.5 mm larger fronts on high bite tracks and have noted on-power push coming out of the high speed sweepers. Have not driven more than a 25 min. main and tire wear seemed to be roughly even. Will try 1:1, thanks.
Just remember that the side that gets most power will lose the most side grip. So if you get more rear drive you'll get more on power stering as the rear end will break loose a bit (more with more rear drive) and vice versa.
#6419
bad day at the track today
I guess there are days when you just need to accept that shit happens My fuel tank got bent out of shape as well. Its jammed into the upper deck. Dam 1/8th car slammed into me while I was parked on a safety area which broke my throttle servo and sent my car going berzerk hitting a couple of walls at high speeds.
#6420
front end with damaged pipe and spring holder
