1/10 R/C F1's...Pics, Discussions, Whatever... >
Like Tree2897Likes
Old 05-30-2013, 03:15 AM
  #8551
Manny's Avatar
Originally Posted by big-al
This is not a replica but a look alike its the car i would have driven in 68 check again the car as 35 as a number
The same could be said about the body and engine overall; it sort of looks like the Lotus 49 but it's not an exact replica. I had to take some liberties for packaging purposes. The biggest "mistake" is in the engine. The left bank of cylinders should be the forward bank but It's set rearward to make more room for the brushless motor wires.
Anyway keep up the awesome work Big Al. Your take on the Lotus is a real treat for everyone that frequents this thread! Somebody send this guy a chassis!
Manny is offline
Old 05-30-2013, 06:31 AM
  #8552
big-al's Avatar
thank you!!!!!
big-al is offline
Old 05-30-2013, 09:32 AM
  #8553
Luppi Stefano's Avatar
Originally Posted by Giorgio
I'd like to take the chance to introduce some ugpgrade for WRC owners.
“Imola”
is a major upgrade kit for WRC F-One 180mm
Features:
Chassis is made using 2mm quasi isotropic carbon fiber
Semi rigid rear link, which allows different rigidity of the rear links for a better tuning
Multi wheelbase option, on both rear and front side
Variable battery placement with in 20mm range
Flex adjustment on the Upper deck
Car has been designed keeping the racer in mind, so all the adjustment are easily availble in matter of seconds.
A quick note over the name: instead of choosing an acronym or a number, we chose to name this car after one of the most emotional racing tracks.
Contact us: [email protected]
Awesome!
Luppi Stefano is offline
Old 05-30-2013, 06:13 PM
  #8554
Default What´s better Tekin Gen2 21,5 - normal ou RPM?
Hi guys,
Someone could help me?
I not sure about the Tekin motor Gen2. There are two options, the
#TT2403 Gen2 21.5t
#TT2402 Gen2 21.5t RPM.
What´s better option for F1 in outside track?
We have a longer straight about 70 meters.
Thank you very much!
lfboss is offline
Old 05-30-2013, 07:45 PM
  #8555
Marty Peterson's Avatar
Al I must say I love the detail! Fuel lines!!! V/C detail just everything you have done and are doing buddy!
I just sit here in awe of your work! AL anyone notice the rivets on the body?
Marty Peterson is offline
Old 05-30-2013, 07:48 PM
  #8556
Trader Rating: 15 (100%+)
Originally Posted by lfboss
Hi guys,
#TT2403 Gen2 21.5t
it's not so much as which is a better option for a long track if you're racing, it's what does the regulations you are racing under consider legal....
fatboysracing is offline
Old 05-30-2013, 09:06 PM
  #8557
MikeR's Avatar
Hi guys,
#TT2403 Gen2 21.5t
If those are the only 2 choices then I would opt for the RPM motor. These cars can feel like a 17.5 sedan on a straight away like yours. Personally I'm running the SchuurSpeed 21.5.
MikeR is offline
Old 05-30-2013, 10:09 PM
  #8558
For those of you doing the VF1 body...how wide are you making the stripe going down the nose? Are you sticking with the lines right in front of the windshield? Going to get started on mine soon and I hope to come up with some pre-cut masks using my vinyl cutter.
InspGadgt is offline
Old 05-30-2013, 10:16 PM
  #8559
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Get the RPM version. F1 doesn't need as much torque. I have the 21.5 RPM version in my 4WD mini and on the straight, it is quite fast. I'm very close to ordering another one for my F1 but just exploring some options right now. The RPM has a 12.3 rotor versus a 12.5.
And both versions are ROAR legal I believe, at least according to Tekin site.
Dan is offline
Old 05-31-2013, 05:35 AM
  #8560
Sure. I´ll see the regulament again! hehe
Thanks!
lfboss is offline
Old 05-31-2013, 05:40 AM
  #8561
I don´t know anything about this SchuurSpeed. I´ll do search about it.
Thanks guy!
lfboss is offline
Old 05-31-2013, 05:43 AM
  #8562
Yes Dan, i think like you. Is better to F1 more rpm than torque.
Probably i'll buy this rpm version.
Thanks!!
lfboss is offline
Old 05-31-2013, 07:14 AM
  #8563
Thanks!!
a sentence like this and you're making fun of me? spellcheck threw up no flags..
Old 05-31-2013, 07:34 AM
  #8564
Michal101's Avatar
Trader Rating: 13 (100%+)
Thanks!!
I guess when you think about it isn't the torque and/or the RPM of the motor also very, very dependent on the gearing (pinion/spur) on the car itself?
Michal101 is offline
Old 05-31-2013, 04:05 PM
  #8565
How? I don´t understand your comment. Can you be more clear?
lfboss is offline
