Tamiya TB-03
#1832
Part number for TB03R is 84109, most of the time the kit number starts with 8 or 9 is limited release.
#1834
#1835
The older blocks pretty much fit. I've also used suspension blocks from the TB02R, EVO IV & IV MS, & EVO V. They all pretty much fit, but the differences are with the height of the blocks. Some are thicker at the bottom than others and when using on the TB03 since some are inverted, there are differences in the thickenesses of the areas where the screws go into.
#1836
#1837
#1838
Hi all,
I notice in some pics people are using aluminium rocker arms on this car, are they the ta05ifs option Ali rocker arms, do they fit the TB03 too?
Also, what is the steering upgrade needed, the carbon link or some other pieces?
Finally, what would be good gearing for both 10.5 and 13.5?
Thanks,
Dave
Thanks,
Dave
#1839
Hi all,
Thanks,
Dave
Thanks,
Dave
yes the rocket arms are the ones used also on TA05ifs, code 53993, re gearing is hard to tell you the final ratio, its depending on which esc you are using. On my model i'm using a team wave esc, and using a 10.5 motor my final ratio is around 7. I replaced the original spur with an 88 tooth pitch 64.
Ciao
Max
#1840
Thanks for the info!
To improve the steering, is it the Ali steering parts, or the carbon steering link, or both which are needed to reduce slop?
#1841
#1843
Hi guys,
This tread seems to be almost dead, I still want to post my newest mod to tb-03 Diff :
I fitted new 12-3/32 Ball Diff gear of TRF502x !
upper tb-03 gear , lower TRF502x gear
finished Diff:
It feels really smooth and moreover now it can stand 13.5 with boost!
You need:
Tamiya 51438 TRF592x Ball Differential Gear Diff
12pc 3/32 or 2.4mm Diff Balls
--> file about 0.5 mm off of the end of the shaft from shorter diff joint
--> don't use the 0.5mm shim between the 850 bearings
have fun!
finished Diff:
You need:
have fun!
