Associated RC12R5
#2296
#2297
thanks tonyk, i wasnt aware of this. i have one ordered.
You can run this:
http://www.shopatron.com/products/pr...6.58610.0.0.0?
#2298
#2299
decals...
id like to do a budweiser themed body. anyone know of a company that makes a decal sheet. if not, im open to other ideas. im just looking for a company that makes major brand decal sheets. target, dupont, marlboro, you get the idea. thanks in advance.
#2300
do the Hot Bodies 12X spur gear work on the rc12r5? does anyone else make 64p spur gears in one tooth increments like them that fit the rc12r5?
#2301
Very high quality, 12 ball configuration.
http://www.nexusracing.com/index.php?cPath=145_321_375
#2302
has any one ever had this problem.
i bought a 12r5 today and it was all new in the box except for the chassis. he had replaced it with his old r5 chassis and put the new one on his r5. so it still had all the r5 parts just the chassis had some use on it.
as i was putting the rear end together i noticed it did not line up.
here are pics to show you.
any one know what my problem could be?
thanks.
thanks.
#2304
ok thanks. now i need to find out why lol
#2305
Yep, that is a R5.1 bottom plate and a R5 topplate. The R5.1 bottom plate is the same as the 10R5 en a little wider than the stock R5 pod.
The motormount and left bulkhead are both R5 so the best you can do is either ask the guy you bought it from to give you the correct (R5) bottomplate or order one somewhere...
Also, I noticed that the crossbrace is mounted in the wrong direction...
#2306
#2307
guys dont forget about that "brushless update" that came out where they used some 10r5 parts on the 12r5. he should be able to just get a 10r5 toplate and the proper hubs and be good to go, right? the bulkheads and toplate on thr r5.1 are totally different from the rc12r5 and rc10r5. i cant find the pages onteam associated's site right now, but before the rc12r5.1 came out they changed the rear pod on the 12r5 with some parts from the 10r5 so that brushless motors weight was balanced better
#2308
Trader Rating: 50 (100%+)
Yokomo 12R5.1 Rear Brace
Hey Team,
I have ordered an extra Yokomo 12R5.1 Rear Brace that I have for sale, if any of you are interested please feel free to send a pm.
Regards,
Alex
Regards,
Alex
#2309
droop adjustments...
how do you adjust the droop for the rear pod. i also understand you can adjust it for the front end. how is this done. the manual sure could be more intuitive for us newbies. thanks in advance.
#2310
thanks.
thanks.
