Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 08-12-2009, 02:55 AM
  #9811
caltek1's Avatar
Trader Rating: 38 (100%+)
iti20090,
We have found that running 60D's on some tracks might be faster on the straight ,but the advantage is lost on the corners. The fastest laps are from cars fitted with small tyres due to the pushing/braking into corners of 60D fitted cars.
However at the end of the day the decision is yours.
Another person who can offer tyre and advice setup would be z-mann, however he doesn't post much these days.
Regards,
Calvin.
caltek1 is offline
Old 08-12-2009, 03:56 AM
  #9812
mild seven's Avatar
Trader Rating: 63 (100%+)
Originally Posted by cannon
Be careful with HPI tyres. There are two versions of the X pattern ... belted and non belted. The non belted is not that good.
We use the Ride tyres here in Sydney. If using a full insert they work extremely well as a front tyre,. In particular the 3035. And some guys really like the 3020 as the rear tyre
yeah i had a set of those non belted ones a couple of years ago, complete junk.
the ones metro hobbies have are the belted x patterns.
mild seven is offline
Old 08-12-2009, 10:37 AM
  #9813
niznai's Avatar
Originally Posted by caltek1
niznai,
Regards,
Calvin
Thank you Calvin.
The problem is here nobody races minis, let a lone a RWD mini from last century like the M02. As for grip, we race on carpet and we're struggling for grip with 4WD cars, so there.
But I know what you're talking about. I have tried all the tires and inserts I could think of (I am not actually gluing the tires anymore since it makes no difference and I was running out of rims, I am only testing the car with a silvercan, so I can pop the tires off quickly and pop in a different tire or insert or more foam, etc).
Anyway, I'll keep trying and pop a question here every now and then. At the moment S grips with TC Sorex medium A type inserts cut down to size and soft Tamiya foam seem to grip best on our carpet. I can drive the car with a very smoothly controlled trigger finger without spinning out, but I am not fast.
And I agree, suspension is a joke on my car. The suspension arms flex to the max before the damper shows any sign of operation.
And by the way, someone was saying some pages back that M05PRO kits are gone. For someone whoy wants one really really bad, I know where two kits are on the shelf and may be persuaded to disclose the location.
niznai is offline
Old 08-13-2009, 09:27 PM
  #9814
OP.1183 M-chassis reinforced free wheel axle - 9/19
wth is that?
redbones is offline
Old 08-13-2009, 09:37 PM
  #9815
Originally Posted by Mini Racer 95
is that the chrome chassis
it's the M03-R (non-blue)
torg is offline
Old 08-13-2009, 10:54 PM
  #9816
doriftu's Avatar
Trader Rating: 11 (100%+)
wth is that?
could this be the rear wheel axle?
doriftu is offline
Old 08-13-2009, 10:57 PM
  #9817
Skitee's Avatar
That is what it sounds like
Skitee is offline
Old 08-13-2009, 11:13 PM
  #9818
mcdogboy's Avatar
Only thing it could be by the description.
mcdogboy is offline
Old 08-13-2009, 11:30 PM
  #9819
thought so too. what a confusing name to give it. btw, I've never bent a rear axle yet.
redbones is offline
Old 08-13-2009, 11:33 PM
  #9820
mcdogboy's Avatar
I have
mcdogboy is offline
Old 08-13-2009, 11:51 PM
  #9821
Skitee's Avatar
They get bent pretty easily when the guy at the rear of the grid doesn't see that the leaders have tangled and ploughs into them flat out.
Skitee is offline
Old 08-14-2009, 03:51 AM
  #9822
Trader Rating: 35 (100%+)
Default Servo recommendation
Please recommend a servo for my new Mini (M05). I don't want to spend a lot of money, but I want a reliable servo. Metal gears, bearings are probably good for Minis, I assume???
Geppetto is offline
Old 08-14-2009, 04:04 AM
  #9823
cannon's Avatar
Reliable, metal gears and bearings means you have to spend some money
cannon is offline
Old 08-14-2009, 05:31 AM
  #9824
MD
MD's Avatar
Trader Rating: 136 (100%+)
The Hitec 625mg is good.
MD is offline
Old 08-14-2009, 05:40 AM
  #9825
cannon's Avatar
Hitec = rubbish
A very por quality servo
Just stick to Futaba or KO
cannon is offline
